PCIII Install
Old Feb 11, 2007 | 11:00 AM
WARG's Avatar
WARG
Default RE: PCIII Install
Rhubarb, do you have a spring seat? What are the two round things on your rear fender?
Old Feb 11, 2007 | 01:59 PM
Rhubarb's Avatar
Rhubarb
It's a regular Deluxe seat. It mounts with two screws in the back instead of the screws on the side of the frame. I'm not sure why though.
Old Feb 11, 2007 | 09:01 PM
defenderp's Avatar
defenderp
How did you get your fuse box to sit lower? I bent the tabs per the instruction and got the relays lower, but I could not get the whole mess to the edge of the tray.
Ed
Old Feb 12, 2007 | 02:03 AM
Rhubarb's Avatar
Rhubarb
A lot of pushing!
I put the cover back on and pushed... it finally slipped down where it needed to be.
I didn't like doing it, but it seemed to go without damaging anything.
You might need to bend the tabs back some, mine caught if i remember right.
Old Feb 12, 2007 | 02:22 AM
WARG's Avatar
WARG
I watched the tuner install mine, he had to do some pushing as well. But yeah, check to make sure the tabs aren't catching.
Old Feb 12, 2007 | 05:08 PM
FACTION95's Avatar
FACTION95
I installed mine where the alarm would go in front of the mud flap. There is barely enough room for the plugs let alone the pc3.
Old Feb 12, 2007 | 06:45 PM
clueless's Avatar
clueless
07 Fat boys are different because we have the 200 rear tire so no tray for our install. have to install behind the mudflap. There is a thread on install on a 2007 Fat boy with pictures if you do a search in this forum.
Old Feb 26, 2007 | 03:47 PM
Dinger's Avatar
Dinger
Installed mine yesterday, it's under the mud guard. Talk about no room to for the battery. Had to destroy the relay tray.Not sure the download worked so I'm taking it toa dyno todial it in.
What did you do with the O2 sensor and orwires after you installed theeliminator?
skyline090
Mar 5, 2010 07:25 AM
grsgt1
Mar 9, 2009 07:12 AM
05 HD Deluxe
Jun 9, 2008 03:37 PM
miwill20
Nov 28, 2007 03:03 PM
RoadDog2105
Nov 7, 2007 08:24 PM
