Platium Plugs
Old Feb 18, 2007 | 11:47 PM
ultra2006's Avatar
ultra2006
Default Platium Plugs
I saw where someone using SE Platuim Plugs in there reg bike, and it starts better and no codes, is this right anyone got any pros or cons on it.
Old Feb 19, 2007 | 12:43 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Platium Plugs
I use them.......The regular plugs that came in the bike new lasted about 6500 miles and then got a sudden miss. I replaced with the same and had same results. I replaced those with the platinums. I ran that set for 30k miles and didn't change them till I put in new cams and a DFO and wanted to monitor my plug color. The current platinums now have 12k and are still running fine.
Old Feb 20, 2007 | 08:14 PM
dchoran's Avatar
dchoran
Interesting.
When I put a PCIII on my '05 Ultra, with the EXACT Dynojet map, it would turn over a half a dozen times before finally kicking in.
Then I changed to SE triple platinum plugs - HOLY BUCKWHEAT!!!!!!!!
I touch the stater button for a MILLISECOND literally, boiling hot or ice cold, and she fires right up instantaneously- UFB.
Had these plugs for over 5,000 miles - NO ISSUES - NO CODES -NO PINGING - absolutely satisfied 100%-never let me down.
Well worth the extra couple bucks for these plugs IMHO. Anybody else using them???????????
Just my experience - hope this helps somebody.
Old Feb 21, 2007 | 11:54 PM
Papamte's Avatar
Papamte
I use the SE Platinums on my Ultra, and I'll continue to use them. Best plugs I've used so far, and I've tried several kinds so far. Over 20k on them now with no problems. Try them, they are bulletproof.
Old Feb 22, 2007 | 10:28 AM
Geoseismic's Avatar
Geoseismic
I use SE platinum plugs in the WINTER ONLY! Platinums are great for quick starts and cold weather operation, but when it gets hot outside, the platnum plugs retain heat and will cause pre-ignition (engine ping). Swap them back and forth spring and fall.
Old Feb 25, 2007 | 02:29 PM
clueless's Avatar
clueless
I have them but read on here about the tip on them not being optimally shapped. I think I will opt for Irradium Plugs next time around.
harleyglen
Oct 10, 2013 10:51 AM
1flhtk4me
Apr 21, 2009 07:31 PM
jf
Jun 20, 2007 09:38 AM
dchoran
Feb 26, 2007 09:19 PM
Patch
16
Sep 20, 2006 05:03 PM
