battery problems
Old Feb 20, 2007 | 03:12 PM
riles10's Avatar
riles10
Default RE: battery problems
the positve pin is not showing....Let meunderstand this one more time about the battery...a battery drained is not the same as being drawn from? anotherwards my battery tender is showing a full battery all the time but in some situationswhen starting, it sounds like its drained....so current at that moment is being drawn away effecting my overall current needed to start?
Old Feb 20, 2007 | 03:30 PM
cjuetten's Avatar
cjuetten
Say you have a bad relay,voltage regulator or what ever andits drawing 1 amp all the time. Over the cousre of a week you have lost 170 reserve amps which is a lot for a motorcyclebattery. Aone amp drain is not much, but over time it really adds up.
Do you havea hard time starting only or are otherelectrical fuctions weak. Head light, horn ect.?
Old Feb 20, 2007 | 04:20 PM
riles10's Avatar
riles10
if that was the case why did the battery completley charge after 15 minutes with a trickle charger but 15 minutes earlier be just short of clicking....not sure about other things not working but my guess is everything was weak...it sounded like a battery going dead after each try...but 15 minutes and a green tender light later it fired up nice..you would think it would need to charge all night on a trickle just to get it back to starting strength...few things I might add to your earlier question about other things on the bike not working right lately...I have had a problem with the key in the ignition when starting..sometimes completelty dead and headlight not on(speed odom on though)....but turn the key to off and on a few times and bingo headlight on and bike starts, never weak...could be independent of this problem or maybe their tied? someone told me to spray a little wd-40 on the key and that might help the contacts better, which it has...only happened once or twice since but happened alot before that...does this help any? or does it confuse you more? LOL....anyways back to the battery..I believe the battery is not getting drained but rather is being shared with something else at that moment when I'm starting...only to start fine after a small trickle and movement of that wire....checked the connections everything is clean and tight..anyone chime in..thx JR
Old Feb 20, 2007 | 04:37 PM
Sammi's Avatar
Sammi
Based on what you describe with no juice for headlight, and then Ok after turning ignition switch on and off, sounds like a bad ignition switch.
Sammi
Old Feb 20, 2007 | 04:44 PM
riles10's Avatar
riles10
could a bad ignition switch account for the draining of the battery or drawing from the battery even if the bike is not running?
Old Feb 20, 2007 | 04:48 PM
Sammi's Avatar
Sammi
If your battery comes to full charge in 15 minutes from being full drained, I'd expect that it's not fully drained at all.
Next time you try to start and it's "dead", throw a meter on it and see if it really is.
Sammi
Old Feb 20, 2007 | 04:54 PM
riles10's Avatar
riles10
I agree 100% its not drained....so this is the mystery question...what problem or problems can give you the false effect of a battery being drained?????
Old Feb 20, 2007 | 10:08 PM
1flhtk4me's Avatar
1flhtk4me
Sounds like you need to check the battery voltage instead of going by the light on the tender.
How do you know the correct battery voltage?
Buy a voltmeter.
Old Feb 21, 2007 | 10:05 AM
dert's Avatar
dert
Bingo....ignition switch..
Old Feb 23, 2007 | 01:27 PM
Silverearl's Avatar
Silverearl
Um You might want to make sure that everything is tight and cleaned.. If ANY connection is lose it will give you the same indications. Check all the ground connections ie:engine, lights, horn anywhere there is a ground check it and make sure it is tight.. Then do the same with the positive.. Make sure ALL connections are tight..
