idle problem after engine work
Old May 20, 2013 | 03:53 AM
Tat2u's Avatar
Tat2u
Default idle problem after engine work
Hi all, I posted this in the engine section but here is probably a better place for it
I just finished doing a s&s 106 and 585 easy start cams build to my 08 street bob.
I did a few heat cycles through the week and road tested yesterday.
Bike runs great, won't be able to get it dyno'd for a while, the closest decent shop is 400 k's away.
Tried a few different maps in my power commander USB 3, the custom map supplied by fuel moto seems the best.
BUT.... I seem to have a problem with the bike idling too low, hot and cold but the cold idle being the worst.
It won't idle at all cold.
sometimes it seems to "just" idle ok when at normal operating temp but usually it will stall unless I give it a bit of gas.
if i hold the throttle open just slightly and lock it there with the throttle lock it idles fine, even down in the too low range like 800 rpm.
Not saying I want it there, just saying it will idle there with out stalling if held there....
It's the same with all the maps.
I reset throttle opening positions with the PC3 USB and they are correct,
Both idles were fine before the build.
I could put up with it until its dyno'd if it could be fixed as part of the tune but just wondering if its not a tune issue.
I have reused my standard throttle body and intake but maybe something that happened when throttle body and intake came off?
Any ideas guys?
Old May 20, 2013 | 07:49 AM
ajayrk's Avatar
ajayrk
Have you checked the intake seals for leaks? Did the wires to the injectors get mixed up?
Old May 20, 2013 | 05:59 PM
Tat2u's Avatar
Tat2u
Pretty sure plugs for injectors are on right, they sort of lined up right by them selves as wiring often does, but yes I'll check that out and for intake leaks.
Thanks for replying
Old May 21, 2013 | 05:25 PM
CDN. RG's Avatar
CDN. RG
try cleaning iac
Old May 23, 2013 | 03:12 AM
Tat2u's Avatar
Tat2u
Yeah mate, thanks, Cleaned IAC valve and all good
tkenney2nd@yahoo.com
Oct 26, 2016 03:32 PM
NWGlide
2014-2024 Touring Models
Apr 9, 2015 09:25 AM
Tat2u
Exhaust System Topics
May 23, 2013 03:11 AM
Rock Head
May 20, 2012 01:24 PM
iommi6
Jul 30, 2006 10:20 AM
