Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I am riding a 2006 fuel injected road king police
it has a 95" screaming eagle upgrade and a cam kit
only at startup and when the bike is cold will it sputter
a touch of throttle will keep it going
but if i dont it will sometimes stall
when riding after its warm and in gears above second it never happens
if the bike is warmed up already it doesnt happen
Their is a service bulletin on 06's to replace the injectors from 8 to 25 degree. I lknow this is for softails, maybe touring bikes also. The symptoms are exactly as you stated - cold starting and running problems. The ecm will need to be reflashed also. This was a free fix from the dealerships.
I found the service billeting and it appears to effect all the twin cam 1450 engines
I will follow up with the stealer to see if the will honor
Thanks for the tip!
