Thunder-Max
Good luck to guys ordering the Thundermax. Started to install mine today and the map they pre-installed is way off. Been trying different combos of there data base all day and can't seem to find a good map...getting discouraged. Glad to remember they have a 30 Day money back. Not bad mouthing. Just frustrated. I called tech support at 4:30, they close at 5:00. Slightly helpfull, slightly in a hurry to go home at 5:00. Gave me enough info to get me more frustated. If anybody has any map ideas I'm willing to listen.
06 HD Streetglide
95"
Ported/Polished Heads
211 Cams
8 degree injectors
Straight pipe exhaust[>:][&o]
Theyonly have two possible maps..neither have the headwork or 8 degree injectors.
End of a long afternoon. I'm thinking PClll next week.
DJK
Thanks again...
DJ,tryloading a more closely matchedbase map into the EFI Controllerandthenride the bikefor several cycles. Every time the ignition is shutoff and then turned back on is a cycle.If you ride for about 10-20 miles, pull over, shut the bike down, then restart it and go ride for another 10-20 miles. Repeat this several times.Your cycles should be representative of your normal riding routine. For example, you wouldn't want to ride for 10-20 miles in stop and go traffic. Turning off the ignitionallows the EFI controller to make the learning adjustments from the auto tuner.I'm definitely no expert, but this is the method I learned from talking with the Zippers guys and it worked for me. Definitely change the base map to one that is closer to your bike's setup. Once you get the TMdialed in, you'll love it.
DJK
Enlighten me please, I thought the Thundermax was "plug and Play".............no matter what the configuration.........no?
The unit requires a "base map" to be loaded into the ThunderMax ECM. The map contains information regarding your motorcycle's make, engine type, piston, cam, air cleaner, exhaust pipe, muffler. The engine type, air cleaner, exhaust/muffler type are the three most important pieces of info the TM needs, tobe able to autotune your bike. Once the base map is loaded into the TM, you need to initialize the unit by cycling the ignition on & off three times, waiting 30 seconds between each cycle. You then start the bike twice, letting it idle 10 seconds between starts. Then you fine tune the idle settingsusing a laptop computer, connected via a serial cable to the TM's ECM. It's not a very complicated process, and the only downside is that there aren't many base maps to choose from. But then the tech support guy at Zippers told me that the unit will autotune your bike to 90% with any map, and95% with a map close to your bike's configuration, soI guess a huge map data base is not necessary.He also said that updated mapsare developed continually.Once you finish all of the items mentioned, the unit is now ready to autotune your bike, continually adjusting the A/F ratio in 256 rpm increments to a default value of 13. Of course, the unit is also capable of being adjusted manually. The ThunderMax is no more plug and play thanmy PowerCommander. The only problem I'm having with the TM so far, is the constant popping on decel. The performance I'm getting from the unit is great.
DJK
I know in my software there are about 300 different maps i think that's more than a few, plus you can make your own map. I did that with mine, made it from their list of different components . if you don't see exactly what you have pick whats close.
You need to go through the software and find these things, it's a little bit of a pain until figure it out.
Also go to the vtwin forums and go to the EFI maps pagethere they have a link with a whole lot of info on it.
I don't want to bust your ***** but you guys are the first people i have heard complain about it.
It will takeat least a few hundred miles to auto tune, you have to be patient. Only thing i know , it's the best money i have ever spent on my bike.
Guys, Thanks for the input. I have the weekend to try to dial it in. The straight pipes are primarily because we have put a lot of custom features on the bike and try to show it probably more than ride. Not a trailer queen, but we don't get a chance to ride as much as we would like, so I wrench on goodies for it. I am new to this forum and will get some personal info and pics posted soon as I can. On this issue it might be the programmer and not the program. If I can't get it by Monday I'll try tech one more time and let them walk me through. This set-up also has the Zippers nitrous assist system so I really would rather get it up and going instead of taking all this off, it is just hard to swallow when you've dropped a $1200.00 expecting it to be ready to go and now I've spent half a day and got nowhere. I'mgood with a wrench, but computers FI and carbs get into me into unchartered waters. It's sites like this that help pick up where the tech lines leave off.
It's very important you do the intial starting sequence first.
Thanks again...
Make sure you set the IAC up correctly. Then just ride it and let it tune itself, unless you screwed something up every time you ride it , it will get better.
I don't know what you guys are doing wrong but the map doesnt even need to be that close, it just will take longer for it to tune itself.
Maybe more time riding the bike for these guys is what they need.
Thanks djkolp for your explanation of how the TM is to be setup.
DJK
