Brake lights
Old Oct 2, 2013 | 01:53 PM
Seveneyes's Avatar
Seveneyes
2nd Gear
Default Brake lights
Ok I have a costume 07 Fatboy and now the brake lights wont shut off. I checked my front brake switch and it seems to be in working condition. I am stuck right now any help would be greatly used.
Old Oct 2, 2013 | 03:26 PM
Mr. Wizard's Avatar
Mr. Wizard
Chances are it is the rear brake switch. It's hard to get to but you can pull one wire off if it and the brake lights will go out. About 20 bucks at HD for a replacement switch. You will need to pull the head pipe off to get to it then bleed the back brakes when you are done. May as well grab a set of exhaust gaskets and a fresh can of DOT 4 while you are at it.
Old Oct 3, 2013 | 06:33 PM
Seveneyes's Avatar
Seveneyes
2nd Gear
Thanks this help greatly. I removed one of the wires to the rear break switch and the brake lights went out so I am guessing that it is the rear one that is broken. Also how can I tell if my Fatboy is a FLSTF or a FLSTFI?
Old Oct 3, 2013 | 06:40 PM
Mr. Wizard's Avatar
Mr. Wizard
The I stands for Injected. So, if you have fuel injection your FL is an I model. Some models dropped the I since that is all HD makes now.
If you are wondering if the "I" will make a difference in your rear brake switch it won't matter... they are the same part number.
Old Oct 3, 2013 | 06:45 PM
RANGER73's Avatar
RANGER73
There was a service bulletin on the rear brake light switch, not sure on the years though.
Old Oct 3, 2013 | 07:55 PM
Seveneyes's Avatar
Seveneyes
2nd Gear
oh cause I found ACCEL 181101 Stoplight Switch on Amazon.com but it was saying that this part wont fit the I models, but I order that part will it fit?
Ranger12s
Shovelhead
Sep 30, 2017 08:27 PM
MURPHCC1
Electrical/Lighting/Alarm
Jun 8, 2014 10:04 AM
Hrlyrider
Dec 2, 2013 04:32 PM
Rock Chalk
Jun 30, 2012 04:49 PM
mpaquette
Jun 16, 2012 08:58 PM
