ironhead issues
Old Apr 5, 2014 | 06:28 PM
IronHeadDrew's Avatar
IronHeadDrew
Default ironhead issues
I have an 84 Ironhead. I just had the top end rebuilt, new leads and coil and timing.My problem is my bike is running good till i go wide open. Then it starts to studder or miss like its over loading or too rich. If im just cruising, itll go to 65mph and thats it. Then its starts its studdering ****.Im not sure of the problem and could use some desperatley needed advice/help.
Old Apr 7, 2014 | 11:34 PM
Frigeratorman's Avatar
Frigeratorman
I assume you have broken in the top end as of now?
Do you have the correct type plugs in it? That is an electronic ignition bike from the factory,so,you need suppressor plugs(resistor plugs) for proper operation.
Another thing may be the plugs are too hot for highway riding.You may need to go one step at a time colder for highway running.
What sort of burn are you seeing on the plugs?
Black and wet? Rich and oil burning
Black and sooty? Too rich
White or pink? Too lean
Tan to latte' color? Good burn
What fuel are you burning in it?
That is one of the models that are the low compression epa gifts to the public and need to run on lower octane than 93 or higher.
IIRC, it has a tremendous amount of spark advance,like 55*,so if you use a dial back timing light,set it accordingly.
Was it doing this before you had the top end rebuilt?
BrandonNull@yahoo.com
Engine Mechanical Topics
Jun 11, 2011 07:53 PM
Dumai
Jun 6, 2010 05:20 PM
wildbillshdsoftail
Aug 10, 2009 09:45 PM
JimboFXD
Ironhead
Oct 31, 2007 10:05 PM
ksoggs
Apr 29, 2006 03:05 AM
