Softail codes
Old Jun 16, 2014 | 06:39 AM
fourhour's Avatar
fourhour
Default Softail codes
I'm having trouble getting into the diagnostics on my 02 Deuce. Read a lot and watched some videos, but I come up with a D01CLr (and so on), not the DIAG readout on the odometer. Is this normal if there are no trouble codes?
Old Jun 16, 2014 | 07:29 AM
Oz Nightrain's Avatar
Oz Nightrain
From what I remember of looking at codes on my 06, it always says 'DIAG' when you enter the diagnostic function. If there are no current codes it will say 'NONE'.
Old Jun 16, 2014 | 07:35 AM
Oz Nightrain
I think 02s are different to 06. You may need this method. http://www.ehow.com/how_5556684_pull...on.html#page=0 or https://www.hdforums.com/forum/showt...5164&styleid=9
Old Jun 16, 2014 | 12:12 PM
fourhour's Avatar
fourhour
Originally Posted by Oz Nightrain
Thanks OZ, I tried this method: https://www.hdforums.com/forum/showthread.php?t=385164&styleid=9
as you suggested and didn't get any codes so I'll assume I'm trouble-free. I'll swing by my buddies shop to verify this.
Just a note, I had no luck with this step: 1: Set Run/Stop switch to off but I tried it with the switch on and was able to complete the test.
Hence, the reason I'll take it to the shop.
Thanks again.
Big09StreetGlide
May 9, 2012 05:30 PM
DPete
Nov 12, 2011 03:07 PM
intimidatorswrath
Jun 13, 2011 01:48 PM
wildbandit
Jun 26, 2007 05:43 PM
twodogs
May 10, 2005 12:48 AM
