MAP updates for old SERT?
Hi guys. I have a CD for the SERT, but it only has maps for the TC88. I'm fixin to put SE255's in my 07, and would like to use the existing SERT that I already have, as I'm running a pretty tight budget.
When I bought my bike, it came with the SERT, but no software, etc. I bought a used SERT off eBay a while back, just to get the cables, CD, etc. So, here I am, just installed the software to my computer, and have no maps that I can use. I'll be running basically a stock 96", with SE 255's when I'm done.
I'm not here to receive a dozen replies telling me why I should use a different tuner, cams, etc. I don't wanna sound ungrateful, because I'm not, but this setup is what I have to work with, and going with something else isn't an option.
The SERT that I bought off eBay for the disc is PN 32107-01E, which is a pretty old setup. I kinda thought it would be updateable, but alas, I was mistaken.
Thanks in advance for your help!
this one is for your setup with the cams. I've adjusted the CI down to 96.7CI
https://www.dropbox.com/s/dkgjfnkpux...76PS005-A1.MT6
this one is for the your setup without the cams.
https://www.dropbox.com/s/v0h2c1iv2e...76PZ005-A1.MT6
what you're going to need to do bud is plug the VCI into the USB adapter and the USB adapter into the computer. Let it find it's drivers. Then go look at the properties (device manager) of the USB device and see what com port the system assigned to it. Then go into the SE software and set that com port as the communications port.
