ECM vs Thundermax Autotuner.
I decided to check more into the T-max update and get someone professional to take care of it for me. I really appreciate all the input..
Take offense at my post all you want... the above information is not correct. Yes the ECM can be flashed by a dealer, but for a True STage 1? That 'flash' doesn't cut it. People buy them everyday from their dealers, too. Still doesn't make it right. ANd... that dealer IS correct. The Digital Technician can only flash the STOCK tune into the ECM, along with the 'download'. It can NOT be used for a performance tune.
They get on here and state how well their bikes runs, etc...
AS COMPARED TO WHAT?
Do any of these guys have a lot of tuning info in their heads? Do they have any TRUE idea on what goes on inside of an ECM?
Of course not, or they would have DIY tuned their bike or took it for a dyno tune.
2007 up? Doesn't add fuel, doesn't change timing. It simply cannot. A motor vehicle dealer simply can NOT alter ANY EPA regulated stuff on a motor vehicle.
SEPST is rumored to be going away. I believe that, too. Ford, Chevy etc, do NOT have programmers and dynos in there dealerships.
It does (The download), I think alter a few of the lesser tables like AE, etc. Proper STage 1 takes a bit of an effort to get done to see the maximum increase in road manners and power. It takes timing and fuel changes to do this. It's snake oil the MOCO sells their customers. What that actually shows is: our bikes are pretty robust in what an engine can truly take and then run fine later. Like the desert testing or having a download instead of giving the bikes some fuel. All of this is why a 2013 bike runs way *** hotter than does a 2005 bike .... it's the EPA induced stuff hanging on the bikes we buy now.
I would rather see a friend have a fuel pak that do a download.
Inside the ECM, software switches get 'set' by the original flash to the software at the factory. "Tunes' and Tuning devices are made to alter those switches. And all of the performance tunes use different setting on the switches. The Dealer Digital Technician simply cannot reach the various ares that these switches reside. It takes a actual tuner to do the swicthes thing. It is made to first and foremost reach those switches.
Nuff said.
And, as far as a TMax goes? In ANY DBW bike? I am 100% against those. Too big of a step backwards in time.
The OP can do what he wishes to do, and I wish him well with the help some are giving him, like Jim. But... before I, myself, plunked down a penny, I would revert back to the Delphi ECM, buy a TTS or PV for around $4-500 and have a LOAD based system running that bike.
In 2008? I get it why someone would have used a TMax. AT the time, that really was the best there was for a DIYer. But, times have changed since that time. Flash tuning came of age for the DIY guys, and if you have no personal knowledge of such? Why denigrate it?
I myself have personal knowledge of both systems, and me? Ask Jim...
... I will take the Delphi any time.... especially after 2007up bikes. For sure 2008 bikes. myself, again, I would even take it for bikes 2002 and up, but THAT is only me. I have a dyno to do those, but I fully understand using a TMax 2002 to 2004 bikes. GOOD DIY solution.2005 and 2006 bikes can be converted to run O2 sensors just like their 2007 cousins for $100, and then one CAN run a PV or a TTS to tune those bikes.
Yes, the download simply stinks anymore and is not a viable TRUE solution to a Stage one. But a $450 TTS and some DIY time surely is. Those Delphis from 2008 and up are simply the best bet going. ION sensing and using a MAP sensor is the way to go.
This person may be who made the videos you watched.
Just because I don't like em so much anymore like I did in 2005 ... I want to be SURE your TMax is good and you not spend any money needlessly.
