Headlamp/Bright Indicator Question
I just changed my headlamp on my 07 Softail Springer. Does the headlamp/bright indicator stay on before the bike is started and then go off? The other thing I notice is that when the bike is off and you go from low beam to high beam the dash indicator light also will adjust with the light change as well. Maybe this normal but I want to make sure before I proceed.
Does the front headlamp from the main harness unplug and is itreplaceable?
Thanks,
Perry
