Ironhead A place to talk about Ironheads.
electrical question
Old Apr 14, 2007 | 12:04 PM
wizardry68's Avatar
wizardry68
Default electrical question
what do i actually need to wire my ironhead? i do have a new wiring harness. bought that last year. no turn signals just basic kickstart. do i need to have a module that i have seen in my catalogs? hate to pay that kinda cash right now. all i have to do is wire the horn head and tail light ignition and run wires to generator and regulator. im running i hope 12v. i hope i didnt leave anything out. this is my last and final majior hurddle i hope. thanks lanky
Old Apr 14, 2007 | 02:49 PM
cswanson's Avatar
cswanson
Default RE: electrical question
I just got done rewiring my 71 XLCH. It seemed like a daunting task at first, but if you take it one step at a time it isn't too bad.
If you don't have one already, I (and everyone else) highly recommend getting a genuine Harley service manual. It has a schematic of all the wiring as well as bunches of other good information.
I don't know what "module" you are referring to, but I would wager a guess and say you don't need one. On my bike I separated the wiring to/from the ignition, generator, regulator, coil and ignition switch into one catagory and the wiring for everything not needed to run into another catagory.. ie: lights, signals, horn, etc. Then I went step by step and wired up one component at a time until I had a running bike. After that was completed I wired up everything else.
The materials I used to wire up the bike were wire strippers/crimpers, soldering iron/solder, electrical connectors of various types, wire, and heat shrink tubing. The schematic also comes in handy too ;-)
I hope this helps some,
Chris
Old Apr 14, 2007 | 04:49 PM
wizardry68's Avatar
wizardry68
i have the book but i get confused on the diagram.
Old Apr 14, 2007 | 06:32 PM
piniongear's Avatar
piniongear
Here is a simplfied wiring diagram I drew up for another member. Perhaps it will make things easier for you.
This diagram has the lightning circuits, turn signals and starting circuit...as well as the ignition circuit. Let me know if it helps.....pg
[IMG]local://upfiles/8331/B0A5D8A9B53B495597FB5F4A52B2F0C9.jpg[/IMG]
Old Apr 16, 2007 | 04:09 AM
sepixlh's Avatar
sepixlh
Here is one version...
SGT.D
Jan 27, 2025 10:03 AM
bl_dg
Electrical/Lighting/Alarm
May 7, 2014 09:38 PM
65_glide
Panhead
Aug 9, 2010 10:53 AM
bberck
Feb 8, 2010 06:55 PM
tagreen2000
Oct 8, 2009 08:53 AM
