Ironhead A place to talk about Ironheads.
Generators
Old Jan 3, 2021 | 09:41 AM
Steve Burns 1's Avatar
Steve Burns 1
Stage I
Default Generators
Okay. So I have a 76 sporty and a 77 basket case. I took the generator from the 77 and mounted it on the 76. It would not bolt on unless I turned it around so that the connections were pointing down. Its a 29975-65B Hitachi for Harley-Davidson. Will this be a problem
Old Jan 3, 2021 | 10:36 AM
Joe12RK's Avatar
Joe12RK
Can you re-clock the brush end so they point where you want?
Old Jan 3, 2021 | 10:47 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Sounds like the basket case 77 generator was disassembled and put back together. Might try removing the long bolts and turning the drive end cover 180 degrees.
Old Jan 3, 2021 | 10:36 PM
83XLX's Avatar
83XLX
No, it’s not a problem as long as your wires reach to the correct terminals. I have a Hitachi on my ‘83 and the terminals are on the bottom, too - that’s just how they are made. Great generators, and they put out more amps than the older ones do.
Tinker82
May 9, 2020 02:51 AM
maverickwolfe
General Topics/Tech Tips
May 28, 2015 10:57 PM
bmedeiros678
Jul 16, 2009 08:04 AM
mike jazz
Nov 2, 2008 08:09 AM
kalamitty
Aug 31, 2008 05:43 AM
