Ironhead A place to talk about Ironheads.
Brake fluid
Old Sep 1, 2007 | 07:40 AM
jdusty21's Avatar
jdusty21
Default Brake fluid
Is there any special type of brake fluid to be used? my 79 is low and I dont want to cause a wreck like on my old triumps using the wrong brake fluid and ruining all the seals?
Old Sep 1, 2007 | 09:05 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: Brake fluid
It should have DOT 5 in it. If in doubt, flush it out.
Old Sep 3, 2007 | 02:37 AM
sepixlh's Avatar
sepixlh
ORIGINAL: xxxflhrci
Flushing isn't enough, so if you have any doubts you need to CLEAN whole system. Cleaning can be done with isopropyl or some alcohol based fluid, don't use Jack D :-) there is better use for that.
Mixing DOT 5 fluid to any other fluid ( also DOT 5.1) can cause seals to swallow useless.
stilup
Jul 16, 2020 09:53 PM
rhd01
Feb 6, 2016 07:09 PM
Sgt_Jim
Apr 5, 2011 09:35 PM
oldtech
Wheels/Tires
Feb 2, 2010 05:48 AM
HDF Tech
Feb 26, 2006 03:18 PM
