Ironhead A place to talk about Ironheads.
backfiring....
Old Sep 7, 2007 | 01:22 PM
C_hunter77's Avatar
C_hunter77
Default backfiring....
1977 xl,1200 hd kheincarb was flooding gas dripping out of bowl and base of accelerating diaphram assembly.....i took carb apart cleaned reassembled ( ive done this before and problem was solved) adjusted pushrods, started bike...front cylinder immediatley backfired..blue flame coming out of drag pipe let idle soon rear cylinder backfired but not as much as front......rode down the street bike was real jumpy...any suggestions for solving this problem? thanks
Old Sep 7, 2007 | 06:03 PM
3 SPOKE's Avatar
3 SPOKE
Stage III
Default RE: backfiring....
sounds like your ignition timing's out,, or you've an air leak on the intake manifold,, or carb flange, making your mixture too lean,,
Old Sep 7, 2007 | 06:28 PM
GrayRider's Avatar
GrayRider
Might need a float adjustment, if gas is pouring out of it. Don't mess with the timing, but pull the points cover and make sure the timing cam is tight.
But once again, if gas is pouring out the carb, it's more than likely a carb problem and not a timing problem.
Old Sep 7, 2007 | 08:27 PM
C_hunter77's Avatar
C_hunter77
thanks il look into those suggestions. i called my buddy and asked his opinion he said the plugs fouled from being flooded and new ones will get me good to go...imma try this asap look at everything else and see where i stand....thanks
Old Sep 9, 2007 | 05:34 PM
C_hunter77's Avatar
C_hunter77
replaced the plugs gapped as specified she fired up and is runnin well....back on the road!!!!!!!!!!!
NickNico
Flathead
11
Nov 15, 2011 03:35 PM
randybecker
Sep 14, 2011 11:29 PM
danrider44
Engine Mechanical Topics
Sep 1, 2011 06:29 AM
JohnFlorida
Exhaust System Topics
Apr 26, 2011 02:33 PM
1989hd1200
Jun 1, 2010 04:41 PM
