Ironhead A place to talk about Ironheads.
CAMS
Old Jan 30, 2026 | 08:14 AM
Ron Pinette's Avatar
Ron Pinette
Default CAMS
Can a combo of cams work, say PB+ for exhaust or intake and standard P's for the opposite.
Old Jan 30, 2026 | 08:28 AM
Architect's Avatar
Architect
Anything can work if you are smart enough to figure out duration and clearances so you don't smack a piston with a valve. Real rocket science stuff, you need to talk to someone that does custom grinds for cams, good luck.
Old Jan 30, 2026 | 10:50 AM
Ron Pinette
Thanks, I was just wondering if were an old ironhead trick.
Old Jan 30, 2026 | 01:03 PM
Racepres's Avatar
Racepres
Certainly it will Work, if Clearances are Checked ..as Architect says..
I can tell you that My Bone Stock Ironhead was Good for 12.9 at at 101MPH in the Quarter...Using good ole P Cams...
Old Jan 31, 2026 | 09:22 AM
Joe12RK's Avatar
Joe12RK
For automotive cams, increased exhaust duration was a crutch for poor exhaust ports. Not a problem that needs to be solved here.
Old Feb 2, 2026 | 07:15 AM
Racepres's Avatar
Racepres
But.. Harleys, have notoriously Poor Port design and Flow characteristics.
You just explained Why, the AB cam can wake Up a Shovelhead...Mine anyway!
junglejoe
Engine Mechanical Topics
Dec 19, 2014 06:27 AM
jlb0038
Jul 6, 2011 08:38 AM
jlb0038
Jul 3, 2010 02:55 PM
tgaetto
Dec 1, 2008 02:39 PM
darkdyna06
Feb 24, 2008 11:35 PM
