Ironhead A place to talk about Ironheads.
Major oil leak
Old Jan 27, 2008 | 03:24 PM
bugmann78's Avatar
bugmann78
Default Major oil leak
I have a buddy that has a 74 sporty. It has oil leaking from around the chain area. He tells me he has to add a quart of oil to the primary every time he rides. Could it be the sproket shaft seal? If so how hard to fix?
Old Jan 27, 2008 | 08:15 PM
Grog's Avatar
Grog
Default RE: Major oil leak
Have your buddy clean the bike up really good to get rid of all the oil and grease on the bottom of the bike. Have him go for a short ride ,preferably slow, and look for the trail of oil.That will get youa better idea of just where the oil is going.
Old Jan 28, 2008 | 07:55 AM
piniongear's Avatar
piniongear
'Could it be the sproket shaft seal? If so how hard to fix?'
Easy fix.......pg
[IMG]local://upfiles/8331/4F34B9E5AFB441DB97E5665A6CD5BB68.jpg[/IMG]
Old Jan 28, 2008 | 12:21 PM
bugmann78's Avatar
bugmann78
Thanks for the info piniongear. Going to help him this weekend with it. Any special tools needed?
Old Feb 1, 2008 | 02:55 PM
bykrdan's Avatar
bykrdan
FYI, and perhaps a quick(er) fix; my 79 had similar symptoms: leaked like a basket under the sprocket, and slowly drained the primary. I was thinking the same thing, that the sprocket shaft seal was bad, but it turned out that I was missing one bolt from the gearcase cover, and all the others were loose. Once that was fixed, the leak stopped.
Old Feb 4, 2008 | 02:16 AM
bugmann78's Avatar
bugmann78
It only leaks when he rides. We think now its coming from the shifter shaft seal.
Old Feb 4, 2008 | 08:48 AM
pyro's Avatar
pyro
How did the diagnosis go from the right side of the bike to the left side of the bike. If there is that much oil, be sure to check the oil lines themselves. In taking mine apart for other reasons, I found one of the lines had been rubbed from vibration enough towear a small hole and would quickly become big enough to let lots of oil escape. I would repeat what Grog said earlier. Clean the bike better than it's ever been cleaned before and start it up. Look for a leak before going anywhere. Give it 10 min or more to finally make itself visible. Then, if you can't find it, go for a quick ride. Keep in mind that you may have several leaks, not just one.
Rich
Old Feb 4, 2008 | 10:41 AM
bugmann78's Avatar
bugmann78
On this model of sportster the shifter shaftis on the right side along with the chain. Brake is on the left. It is not motor oil leaking he hasnt changed the oil in it yet. Itis dark. The fluid leaking looks like new oil.
[IMG]local://upfiles/8555/7F1E125137D244AA9199B6790473BEC6.jpg[/IMG]
Old Feb 4, 2008 | 01:52 PM
pyro's Avatar
pyro
Forgot about the right side shift, make's sense now.
Dusty Hawk
Jun 20, 2013 10:29 AM
Jim Dawson
EVO
Apr 24, 2012 08:35 AM
gforrest2
Sep 6, 2009 12:35 AM
Tuffluck
Shovelhead
Sep 13, 2007 12:08 PM
Kess
Oil Archive (no new posts)
Jul 20, 2005 12:25 AM
