Ironhead A place to talk about Ironheads.
Cam Cover
Old Feb 14, 2008 | 07:41 AM
SportsterBob's Avatar
SportsterBob
Default RE: Cam Cover
You are probably better off replacing the cover. In order to fix it you would have to have the crack "stop drilled" andwelded. Looks like the bushing was replaced and the OD of the bushing was too large, thus causing the crack. Another issue when replacing cam bushingsis to have them line reamed......you'll need a spare R/H engine case and reamer to do the job.
[IMG]local://upfiles/53097/CB1F1264DBD74754A847A58D6E910AE2.jpg[/IMG]
Old Mar 22, 2011 | 10:51 PM
thunderpig's Avatar
thunderpig
Stage II
Default Need a 71 Sportster Cam Cover
Any suggestions where to get a good deal new are used ..Alum preferred..
Old Mar 23, 2011 | 05:15 AM
IronMick's Avatar
IronMick
eBay
Why do you need one? Remember that it is not just a cover as it contains the bushings for the cams and other gears. A replacement should have the bushings line reamed with a right side case using a special tool. It is usually better to fix what you have.
Tell us more.
Old Mar 24, 2011 | 01:07 AM
sepixlh's Avatar
sepixlh
Originally Posted by IronMick
eBay
Tell us more.
Agree this, its usually easier to fix what you have.
TXSailor
May 25, 2015 02:03 PM
DTDK
Feb 23, 2012 06:26 PM
55bob
Exhaust System Topics
Aug 5, 2010 07:42 PM
pickupman96
Ironhead
Nov 6, 2009 06:57 PM
dawg
Dec 29, 2006 09:34 PM
