Ironhead A place to talk about Ironheads.
Highway pegs ?'s
Old Mar 29, 2008 | 06:49 AM
csd4682's Avatar
csd4682
Default Highway pegs ?'s
If a 75 ironhead has the aftermarket crome oil filter setup, can you still use highway pegs, it looks like there is an extra hole in the mount for the oil filter that you could connect the extension and peg to. If you cannot, how important is it to have that filter, I think I would much rather have the forward pegs than a little extra chrome.
Old Mar 29, 2008 | 08:06 AM
RJ61's Avatar
RJ61
Default RE: Highway pegs ?'s
First of all, is there any other oil filter setup on the bike? If not then you may find that the "crome" becomes very important. You really need that oil filter system. There are a number of styles on the market to put an oil filter in differant locations so that you can use forward controls or highway pegs
Old Mar 29, 2008 | 10:19 PM
hog4u's Avatar
hog4u
Didn't you just post that your motor had less than 500 miles since a top end rebuild? Truth is there wasn't a filter on it when it was new. But with a new motor I would paint the filter flat black and change the oil and filter at 500.
There are lots of ways to mount pegs if you want them.
Old Apr 11, 2008 | 08:40 PM
72xlhinnh's Avatar
72xlhinnh
6th Gear
I bought a 72 XLH, it has highway pegs & chrome oil filter. there is a notch cut out of the mounting plate for the left peg to fit around filter. (I found this out when I tried to switch sides of pegs to move to a more comfortable position) not sure if this helps, but maybe you can cut or grind a noth in yours.
nobodyknowsme
Milwaukee Eight (M8)
Nov 6, 2017 05:15 PM
switzead
Jun 30, 2014 11:41 AM
btroy
EVO
19
Sep 28, 2008 10:56 PM
grippper293
Oil Archive (no new posts)
Apr 1, 2007 09:40 AM
smithr
22
Aug 22, 2006 01:23 PM
