Ironhead A place to talk about Ironheads.
a note on Bendix carbs....
Old Apr 24, 2008 | 11:08 PM
piniongear's Avatar
piniongear
Default a note on Bendix carbs....
A couple of you guys are talking about having Bendix carbs right now, so I thought I would alert you to a possible problem that can happen to a Bendix.
If you sometime in the future find that your bike will not run because it is fouling out spark plugs at highway speed with a rich black sooty coating inside the exhaust pipes, the cause of the problem is going to be a bad O ring inside the float chamber.
This O ring keeps raw fuel from entering the venturi of the carb. The fuel is forced to flow through the main jet into the venturi under normal operation.
When the O ring degrades, it allows raw fuel to seep past it with the resulting black sooty fouling of the spark plugs.
The fix is to go to Lowes plumbing dept and buy a 10 pack of #5 or #6 fawcett O rings for $1.29. Install one in the carb and you will have it running sweet again first time you fire it off.........pg
[IMG]local://upfiles/8331/C83802F64E07421DA2F8664477C6F2E7.jpg[/IMG]
Old Apr 25, 2008 | 10:28 AM
daimmel's Avatar
daimmel
6th Gear
Default RE: a note on Bendix carbs....
thanks for the information
Old May 6, 2008 | 08:22 AM
Badger's Avatar
Badger
I'm thinking I may have this problem. Going to check it. Thanks for the tip.
invaderb
Jul 1, 2017 06:31 PM
CTP
Ironhead
Sep 1, 2007 06:44 AM
traxsmax
Ironhead
Sep 6, 2006 12:29 AM
SJ12DS
Exhaust System Topics
Mar 20, 2006 07:34 PM
az_fxstc
General Topics/Tech Tips
Apr 20, 2005 10:07 PM
