Ironhead A place to talk about Ironheads.
Smoking Ironhead
Old Jun 2, 2008 | 04:24 PM
dtimekw's Avatar
dtimekw
Default Smoking Ironhead
Newbie here in the ironhead section. I just bought a 79 XLH to wrench on and to keep my hands OFF my Train.............for now [sm=badidea.gif]
Cleaned the carb, flushed the tank, changed oil, compression was 130 psi on both holes.... and to my surprise it fired up! I have quite a bit of smoke coming out of the crankcase vent (near the generator?) once it warms up. According to the service manual, this connects up to the air box which of course no longer exists. How common is this and what do you think it is? On a car, it usually indicates blowby but want to make sure since I am not familiar with this oiling system or the motor itself [sm=helpout.gif]
What a rush though to hear this thing for the first time!!!
Thanks and I am sure I'll be asking more questions as I go thru the bike.
Old Jun 2, 2008 | 05:16 PM
fergerburger's Avatar
fergerburger
Default RE: Smoking Ironhead
what color is the smoke? that is the crank breather vent and it should puff/vent crankcase air under normal conditions....are you sure its smoking from the tube and not from the exhaust where some oil mist is blowing onto the pipe from the vent....make sure the vent is directed away from the pipe.....
although I own a 71 so yours could be different
Old Jun 4, 2008 | 07:25 PM
dtimekw's Avatar
dtimekw
No, it's coming right out of the vent. Seems like the color/smell is more like exhaust than buring oil. I think it's running rich but still playing with it. Also finding unburned oil coming out of the back pipe ( pulled pipe and saw oil around the valve stem). During the running inspection, also noted the front cylinder is running over 100 degrees hotter than the back cylinder, any reason why? Oil pressure light goes out when I start it, since the pushrod tubes leak a bit, I'll assume both heads are getting oiled, any ideas? Thanks!
marl
Shovelhead
62
Jan 29, 2020 06:46 PM
jws83
Ironhead
Jul 8, 2016 09:54 PM
junglejoe
Apr 8, 2013 07:02 AM
72 chopper
Ironhead
Nov 18, 2007 05:07 PM
Knockman
Oil Archive (no new posts)
Oct 19, 2005 09:09 PM
