Ironhead A place to talk about Ironheads.
grindin' rocks with an ironhead
Old Jun 2, 2008 | 05:12 PM
fergerburger's Avatar
fergerburger
Default grindin' rocks with an ironhead
So I finally fired up my barnyard find after refurbishing for about 3 weeks. It ran pretty darn good for coming out of a field in Wisconsin. But it sounds like it is grinding rocks somewhere in the bottom end near the front...it's either coming from the generator or the crank....I've had Evo sportsters and they are noisy in the bottom end but this is pretty loud.....plugs look good...tan, seems to accelerate good, no issues beyond the noise....primary chain is not loose, etc.....
So do ironheads normally sound like they grind rocks? It does seem like it's the generator making the noise but my experience with other older big twins leads me back to the crank and cases.
Old Jun 2, 2008 | 06:31 PM
pitbull1's Avatar
pitbull1
Default RE: grindin' rocks with an ironhead
Mine did that at one time but just as I started off and released the clutch.Kinda of a knock,grind,vibration all together.Right there by the generator.It was the compensator sprocket.Big round nut that holds it on was loose.
Old Jun 2, 2008 | 09:26 PM
hog4u's Avatar
hog4u
I think he has a XLCH. They don't have compensator sprockets.
Pat
Old Jun 2, 2008 | 10:02 PM
fergerburger
yeah...its an xlch...no comp sprocket....I'm pretty sure its the generator...I can feel the grinding in the generator, not in the cases...but then again....
the bike runs like a hot rod so I'm guessing the bottom end is okay....I guess Ill find out sooner or later
Old Jun 3, 2008 | 06:10 AM
Skinner's Avatar
Skinner
2 bolts remove the generator. Pull it and have a look at it and the drive gear. Better to find out now then have the gear go and get caught up elsewhere to do more damage.
JMO.,
Skinner
Mike Lawless
Sep 26, 2015 08:40 PM
cajun1957a
Shovelhead
Jun 9, 2015 04:22 PM
2kids3pets
Apr 3, 2015 02:25 PM
Rocko Rock
Apr 19, 2009 04:22 PM
Lars
Exhaust System Topics
Jan 27, 2005 04:23 PM
