Ironhead A place to talk about Ironheads.
67 exhaust help
Old May 31, 2009 | 03:04 PM
ironside67's Avatar
ironside67
6th Gear
Default 67 exhaust help
im rebuilding a 67 xlch the pipes i have with the mounting bracket are going to make right turns a bit rough, i was wondering if anyone could recommend a different set up for greater ground clearance. thanks.
Old May 31, 2009 | 03:50 PM
piniongear's Avatar
piniongear
Just saying you have a 1967 XLCH is not enough information you give you any kind of helpful answer.
You need to post some pics of what you have and what the problem is.
Right off the top of my head I cannot picture any kind of ground clearance problem a 1967 XLCH could possible have (making a right turn) with the exhaust pipes. More info is needed......... pg
Old Jun 1, 2009 | 02:28 AM
ironside67's Avatar
ironside67
6th Gear
the frame has been lowered so the whole bike sits lower, the bracket that the mufflers bolt onto is only a few inches from the ground. i was wondering if you knew of anyone that made an exhaust for this motor that can be mounted higher from the ground, i havnt had much luck finding anything. ill post some pictures as soon as i can. thanks.
Old Jun 1, 2009 | 04:17 AM
sepixlh's Avatar
sepixlh
I'd say that only exhaust that you can find to ironhead is dragpipes, so you need to make them...
Old Jun 1, 2009 | 07:09 AM
piniongear's Avatar
piniongear
I agree with Sepixlh, straight pipes are the only pipes you are likely to find. In 1958-1959 Harley made a 2 into 1 High Rise pipe (middle illustration) that went up alongside the rear fender (for using a Sportster in an Enduro, if you can imagine that), but that pipe has long expired. Shown below are some different pipes HD has made for the Sportster.
Even if you could find such a pipe today, it would cost a fortune if the owner knew what he had because it is such a rare pipe.
So what you are left with is to have someone who is a good Tig welder modify a set of straight pipes to give you the contour you want........ pg
Old Jun 2, 2009 | 01:48 AM
sepixlh's Avatar
sepixlh
Sporty Specialties has maybe best selection of ironhead pipes, but for your application no.
Old Jun 3, 2009 | 04:26 PM
ironside67's Avatar
ironside67
6th Gear
alright thanks for the help
the_cruz
Aug 21, 2016 01:11 PM
brenn
Mar 25, 2012 04:36 PM
FLYSBY
Jul 24, 2011 06:07 PM
ironside67
Exhaust System Topics
May 31, 2009 02:55 PM
scribe
Oct 5, 2007 09:12 AM
