Ironhead A place to talk about Ironheads.
Shocks
Old Aug 6, 2009 | 03:22 AM
ironhead_nick's Avatar
ironhead_nick
4th Gear
Default Shocks
On my 76 I want to put the shortest shocks I can get away with. I'm not a big guy 145lbs. The shortest I have found are something like 13.5" center eyelet to center eyelet. I think with my small size I can get something like
11" to work. I have alot of room between the stock shocks and the tire now. Has anyone done anything like this?
Old Aug 6, 2009 | 04:37 AM
sepixlh's Avatar
sepixlh
Lowering bike isn't always simple, as just shorter shocks. You need to check least, chain line (=oiltank, chainguard) inside of rear fender (=bolts, wires). Shorter shocks means also less travel on suspenssion -> harder/stronger spring. Have you tried to adjust spring preload ?
It might be good idea to check how easy is lower rear fender... but you always need to check those clearence issues.
Old Aug 6, 2009 | 05:22 AM
IronMick's Avatar
IronMick
Cut pieces of wood, drill holes in the ends, to see what problems you might run into. This will give you the compressed shock height.
oscardog1
Feb 18, 2016 02:54 AM
85RoadsterXLS
May 31, 2013 06:49 AM
jbarbarian
Mar 17, 2008 11:58 PM
rob i
Mar 12, 2008 12:46 PM
bonez
Feb 9, 2006 01:05 PM
