Ironhead A place to talk about Ironheads.
Spark plugs
Old May 23, 2020 | 07:09 PM
IronMick's Avatar
IronMick
Mine, same parts, sticks out about the same as the original Keihin, perhaps a little less...
Old Aug 3, 2024 | 12:28 AM
Robby94's Avatar
Robby94
I know this is an old thread but figured since there is already one id just ask here. 1984 xlx1000. Was looking at ngk since they're my preferred brand. My question is, it says the Br6hix uses a resistor but when reading it says it has a 5k ohm resistance. Im running a 5 ohm dual fire coil with points NOT electronic ignition. Would this spark plug be ok to use even though it has a resistor or what ngk sparkplug should i use, the B6l like stated in previous comments? Im asking because the iridium's last a lot longer and conduct electricity better so itd be nice to not have to change plugs as often and possibly get better combustion. Any advice would ve appreciated.
Old Aug 10, 2024 | 01:05 PM
83XLX's Avatar
83XLX
The original plugs would have been HD 4R5, which were resistor plugs. As long as you don’t have aftermarket resistor wires or caps, you should be fine.
JohnnyC
EVO
37
Oct 5, 2019 04:27 AM
radio915
Shovelhead
13
May 27, 2016 10:32 AM
boblkat
Apr 11, 2011 07:13 PM
B Will
Apr 7, 2008 12:19 PM
gigiflip
EVO
11
Sep 14, 2007 07:59 AM
