Ironhead A place to talk about Ironheads.
ironhead cylinder heads?
Old Sep 4, 2009 | 09:15 PM
ironsport83's Avatar
ironsport83
5th Gear
Default ironhead cylinder heads?
what other years cylinder heads are compatible with the 83 xl1000 ironhead sportster?
Old Sep 5, 2009 | 07:42 AM
IronMick's Avatar
IronMick
From the 79 to 85 parts book, the part numbers for 79 to early 85 are front 16673-73D and rear 16674-73D. The 73D indicates that any from about 1973 are the same.
The 73D probably means they begin with 1973. However, sometimes the number at the end of the part number indicates the design year not the first year used. Someone else may know for sure.
Old Sep 5, 2009 | 05:45 PM
BRIZ's Avatar
BRIZ
6th Gear
72' was first 1000cc sport.....
pretty sure they are the same....
Old Sep 6, 2009 | 11:36 PM
sepixlh's Avatar
sepixlh
1972 heads might fit but cylinders are different... to be sure 73 and newer OEM#16673-73 and 16674-73 . If I heard correctly, D= hardened valve seats for unleaded fuel 79 ???
I can't confirm this from my "resources"...
Old Sep 7, 2009 | 12:14 AM
FilthyLucre's Avatar
FilthyLucre
The "D" suffix means it is the 4th modification of the part that was introduced in the 73 year. It supercedes -73, 73A, -73B, etc. Any of the -73 numbers will work but the latest is always the safest. Sometimes the changes are cosmetic, or to make manufacturing easier or it may be a real improvement like no lead valve seats.
Old Sep 7, 2009 | 07:49 AM
ironsport83
5th Gear
reason i ask is,i plan on picking up another set and porting them ect ect.I checked with avv on valve guides and they have 2 diff sets either 57-early 83 and late 83 and up for the iron head,one guide has a flange and one is just a press fit.Can i use either one of these guides?
Old Jan 19, 2010 | 09:02 PM
70Weight's Avatar
70Weight
Default What did Ya find out?
My 83 has steel flanges,must be late.
Old Jan 22, 2011 | 09:34 PM
rlcgun's Avatar
rlcgun
6th Gear
how can I tell if it's early 83 or late 83 before I tear it down
Old Jan 23, 2011 | 06:42 PM
scottfisher's Avatar
scottfisher
There is cross-reference mat'l available that you could check your VIN against. However, when it comes to internals it is just best to open and see. If it is valve guides you are looking at you want to check the style and diameter to be sure you are ordering/replacing with the same.
Maturola
Mar 22, 2017 06:40 PM
vbsportster
Jan 3, 2015 11:36 AM
BHBBlacky
Exhaust System Topics
Feb 16, 2012 04:05 PM
Arild
Ironhead
Sep 10, 2009 12:02 AM
72SHOVEL
Classic
Dec 5, 2005 01:06 PM
