Ironhead A place to talk about Ironheads.
oil pressure
Old Oct 18, 2009 | 09:24 AM
sellout's Avatar
sellout
Stage III
Default oil pressure
I am the new owner of a 74 ironhead. This is only my second pre-90's Harley, so i am still learning. What kind of oil pressure should I expect? I believe I am dealing with a stroker kit as well, as this thing runs faster than any other sporty i have ever riden.
Thanks
Old Oct 18, 2009 | 09:37 AM
shepdog's Avatar
shepdog
for the most part i dont think there is enough pressure to show much on any gauge, just make sure oil is going back to the tank and it should be fine.
Old Oct 18, 2009 | 09:58 AM
sellout's Avatar
sellout
Stage III
It had a gauge mounted when I got it. I fired it up and the gauge puked. Figured I would just replace it, but everything I find is 60-100lbs, which seemed way too high. Might look for a lower pressure gauge just to fill the hole.
Thanks for the info.
Old Oct 18, 2009 | 12:55 PM
shepdog's Avatar
shepdog
where was the gauge mounted?
Old Oct 18, 2009 | 05:58 PM
IronMick's Avatar
IronMick
A gauge mounted up top is next to useless, except as a show piece. It will usually show some pressure when the oil is cold then go to zero. One connected at the oil pump together with the oil pressure sender will read true, that is 20 to 60 psi cold to very cold, and between 5 and 10 psi hot oil.
I installed a kind of T fitting at the pump so i could have both the oil light and the gauge. It is actually more like an F, with a 45` fitting behind it.
Old Oct 19, 2009 | 12:35 AM
sepixlh's Avatar
sepixlh
Pressure gauge in rocketbox is waist of money... or show piece as IronMick wrote.
Check from your oiltank that warm oil has steady flow from return line.
Iron lHorse
Mar 18, 2015 10:53 PM
jd8181
Jan 15, 2013 08:24 PM
sportster orange
Jul 8, 2008 10:56 AM
Booey424
Apr 17, 2008 09:37 PM
wizardry68
Ironhead
Jul 21, 2006 01:54 AM
