Ironhead A place to talk about Ironheads.
Pushin Oil
Old Aug 15, 2006 | 10:58 AM
piniongear's Avatar
piniongear
Default RE: Pushin Oil
Part #707 is the transmission drain plug. The trans has no connection to the crankcase and the crankcase has no drain plug. When the base loads up with oil, the oil pukes out the breather tube until the crankcase area is empty. You will not be able to remove this oil by draining the transmission............pg
Old Aug 15, 2006 | 11:27 AM
fdny37's Avatar
fdny37
I'm going to try and start her up today and I will post some pictures of where the oil is pushing. The oil lines running from the case to the heads are steel braided lines and they do not leak. There is a crankcase plug I will provide a photo just for info. I am probably going to bring the bike to a guy named Jessie Stewert maybe you've heard of him maybe not. He has a shop here in Vegas (dragstews.com). Anyway I will try to post pictures but I might be a little slow after all it's 105 degrees and trying to kick it over is hazardous to your health.
Old Aug 15, 2006 | 11:31 AM
Calwoodbutcher's Avatar
Calwoodbutcher
I have a 74 and it has three drain plugs on the cases. One drain plug is under the transmission, one drain plug is under the clutch and the third one is directly under the flywheels. The crankcase and tranny plugs are 1/2x13 and the clutch plug is magnetic.
Old Aug 15, 2006 | 06:54 PM
Neil74's Avatar
Neil74
Part#707 is the plug for the transmission and the plug for the crankcase, the Harley Davidson parts book clearly calls for two plugs. I have a 1975 & 1973 set of cases on my bench as I am writing this, there are three plugs in each set, one under the clutch hub, one under the tranny and one under the crankcase. If you still can't find them there are two in the cam side of the engine cases and one in the back of the primary side. Hope this helps!
Old Aug 15, 2006 | 07:04 PM
pittguy's Avatar
pittguy
Check the case for cracks at lfter block area,pull the block out and clean real good.These cases will crack closest to cylinders usually starting from block attach hole.Hope this isnt so,but can be repaired and not easilly seen afterwards.
Old Jan 1, 2012 | 01:07 AM
FXSLOWRIDER's Avatar
FXSLOWRIDER
5th Gear
Just curious but if Jesse Stuart built the motor and its been doing this since what the beginning of time? why didn't you bring it back to him back in 1980 or when the problem first started happening?
Old Jan 1, 2012 | 11:26 AM
piniongear's Avatar
piniongear
Ah-hhh, this thread is almost 6 years old.
I would not expect a reply to your question if I were you.
pg
Old Jan 1, 2012 | 12:17 PM
FXSLOWRIDER
5th Gear
Guess I should have looked at the date? LOL
Old Jan 3, 2012 | 06:41 AM
GA Ironhead's Avatar
GA Ironhead
I think Ross had the motor built in NY, when he lived and worked there...
Old May 23, 2012 | 08:19 PM
dragstews's Avatar
dragstews
Wouldn't do you a bit of good...
You look at alot of things and still don't see ...
http://www.hark.com/clips/lvrtxfcvgm...youre-an-idiot
Sorry...Sometimes the Truth hurts...
I think he got it fixed...(...LOL...)
http://youtu.be/3jAjJsG0T0o
Mongo43
EVO
32
Jul 29, 2024 09:06 PM
bigbdz16
Exhaust System Topics
Oct 6, 2012 10:25 AM
supersix
Shovelhead
Mar 27, 2012 09:42 AM
Hey Zeus
Shovelhead
Apr 23, 2011 12:16 AM
Screw
Oil Archive (no new posts)
May 31, 2007 07:12 PM
