Botched carb rebuild
Also the intake tracts are oily, not gas, but engine oil. I don't remember the exhaust sides being oily when I changed the exhaust. I do know it's using some oil.
... the old plugs looked pretty good, mostly light tan with just a little bit of black carbon around the edges. ... I tried to check the timing but I don't have a dial back light. When I run the front cylinder to TDC I see the line, not a dot through the window. With the engine running I can't find the timing mark at all even after adjusting the timing either way. If I let it run at a slow idle I see the rear cylinder timing mark through the window with the light. I'm gonna get it to a friends shop who has a good light and have him check it.
I ran the valves too and didn't find anything out of the ordinary.
... But it is slowly but steadily getting worse. ...
Are the 52 and 160 jets stock or has someone been in there messing with it before me?
And finally, there is a valve of some kind mounted between the heads and up high under the tank with two electrical wires and a vacuum hose to the carb. What is it and what does it do? Could that be my problem?
I am not expert on the internal operation of these engines, but oil in the intake tracts might be draining down thru the valve guides or perhaps seeping past the rings. I would not think this is part on the problem getting the engine running well. Unless someone more knowledgeable chimes in on this i would ignore it for now.
Light tan with carbon around the edges is a good looking plug.
According to the Haynes manual the line is the TDC mark for your year bike, and the dot is the front cylinder advance mark. It would be worthwhile to check this. Rotate the engine until the front cylinder is at TDC then check to see if the line is in the hole [EDIT: oops, you have done this and it is confirmed correct]. This is important as it may not have the original flywheels in there.
If it has the original electronic ignition or has been converted to points then when using the light you may also see a rear cylinder mark in addition to the TDC mark as both plugs are firing simultaneously.
It is important to get the ignition timing right before running the engine much. Set the plate so that the standoffs are in the center of the slot. Then try again with the timing light. Run the engine at 2500 to 3000 RPMs [i find that at slower speeds the mark does not sit still in the hole]. I use a 1" length of rubber oil line hose, with one end flattened on a grinding wheel, and that end jammed in the hole tight against the flywheel. That keep most of the oil from spewing out.
This process requires some patience. If your friend has more experience then watching him do it is a good idea.
It may be getting worse as the correct problem has not been accurately identified yet and the changes are not helping so far. We'll keep trying here.
160/52 are the stock jets. If it has the original air cleaner and baffled pipes then these will still work reasonably well. In any case once any problems have been cleared up 165 to 175 and 55 to 58 may be better. But leave it the same for now.
The factory service manual has a procedure to check the VOES. It is also in the Haynes manual. I disconnect the VOES when checking the ignition timing. Ask your friend about this when he is doing it.
You might also print off some of the suggestions we have been making and have your friend review them. It is different when you have the bike in front of you. He may have different ideas, and sometimes it is best to follow just one expert. And let us know what he thinks of our ideas.
I'm sure the rubber plug covering the slow jet is in there snug because I used the new one that came with the carb kit and it was a pretty good fit. I always get kinda confused (more than normal) about which way to adjust the float. I think in this case I want to set the level lower or so that it shuts off sooner? I had no flooding problems before I got my fingers into the carb.
There is no crossover pipe. I know they're not the best choice but for now I'm still running the 2" drag pipes with lollipops. All I have are 3 sets of drag pipes, the other two are 1 3/4" with no baffles or washers. It runs much better with the washered 2" vs the open 1 3/4" so I'm gonna leave them on until I get some of the carb issues figured out. I haven't noticed any black around the pipes but it can't hurt to put some sealer on them I guess.
It'll probably be next week before I can get over to my buddies to have him look at the timimg. I can give it another shot. I didn't want to fool with it too much because I know if you move the timing plate just a little it makes a big change. But I do have it marked so I can go back to the starting point. It does have electronic ignition too.
Back to the garage, pull the carb back off, reset the float, give everything a second look inside, check the timimg, seal the intake bands, seal and check for exhaust leaks, might as well do a compression test while I'm in there. I sure would like to ride this thing instead of work on it all the time......
With the bowl off, hold the body so that the float is hanging vertical; tilt it very little, but just enough to seat the needle. The distance from the mating surface of the carb to the far edge of the float must be 16 to 17 mm.
Btw the float was set at about 14 mm when I took the carb apart again, so much for trying to set it by eyeballin' it.
Shepdog what brand of baffles are you runnning in yours? I bought a cheap set of 4" baffles off of Ebay but couldn't stand the woosh woosh sound they made and took them back out without even going for a test ride. I like the deeper tone and the look of the 2" pipes but I have a new set of 1 3/4" that I'll probably end up going back to. I also have an old set of 1 3/4" goosenecks that I would be willing to cut down and experiment with shorter lengths of pipe if anyone thinks there is any benefit to running shorter pipes........of course, after I get my current issues lined out and the bike running right.
More than likely I will go back to 1 3/4" with...something in them. I just don't want to make that change until I get the other problems figured out.
Went to Terre Haute this morning and picked up another float, needle and a complete carb minus the fuel bowl all for $10 bucks at the best little bike shop in this area. So after replacing the float and going all through the carb again I put it all back together with another set of intake bands with sealer and new clamps. It runs 90% better now. The hesitation or hiccup is all but gone when I crack the throttle open. It did still cough and pop back through the carb a couple of times when I first left on the test ride but after a couple of miles it quit that. Feels alot stronger now and it actually has throttle response now. It's still not 100%. Still need to get the timing checked, still need to check for exhaust leaks after I switch back to the 1 3/4" pipes and still need to do some fine tuning.
The other carb I got today had the spring I needed for the choke so that works like it should again and also has a 170 jet in it. Unfortunately it has a 48 slow jet in it. I have the 52 and 160 jets still in now. Should I try to bump the 52 up to a 58 or so? Do you guys think the 170 would be too much or should I try a 165 first? I'm out just about 1 1/2" turns on the mix. It still has a random miss at speed and I can't help but feel like it's still running a little lean. I'm gonna look at the plugs tomorrow and go from there.
This is a big relief after working on this thing for a month with no improvements. Only thing that worries me is I'm not sure what I did this time to make it better.
