Ironhead A place to talk about Ironheads.
1970 quick question
Old Aug 23, 2010 | 09:46 AM
josh221's Avatar
josh221
6th Gear
thank you so much for the info that answered alot of my questions. No electric start for me. I actually kind of enjoy the kick start. atleast now i have a better grasp on what exactly i own.
Old Aug 23, 2010 | 10:11 AM
The Doctor71's Avatar
The Doctor71
Are you sure that motor is a '70 ?
There is so much on that motor that appears to be '71 or newer (including the Texas notch rocker boxes), I'd suggest another check of the motor s/n is in order.
What are the last 2 characters of your motor s/n ? It should look something like --> 3AxxxxxH_
The "H_" will confirm the year, one way or the other.
Old Aug 23, 2010 | 11:01 AM
piniongear's Avatar
piniongear
I gotta slightly disagree with you there Doc.
The serial number starts with 3A (which is either an XL or XLH) or it starts with 4A (which is an XLCH)
Next, the number has 5 digits. These 5 digits are 10,000 or higher for an XL or XLH (not an XLCH)
In the case of an XLCH you may find the 5 digit number may contain a 'delta mark' as one of the digits.
Following the 5 digits you will have the letter 'H'. This designates the manufacturer which is of course Harley Davidson.
Redundent? Yes, but that is what the letter 'H' stands for.
This last digit will be a zero or a 9. or something in between.
A 'zero' denotes the year 1970.
'1; = 1971, '2'= 1972, '3'= 1973 etc.
A '9' denotes the year 1979.
This is the coding breakdown for a Sportster engine serial number for the years 1970 through 1979.
Before 1970 and after 1980 different numbering systems were used.
pg
Old Aug 23, 2010 | 11:19 AM
The Doctor71
no problem PG. We are on the same page. Your explanation is much more accurate than mine.
Old Aug 23, 2010 | 11:38 AM
piniongear's Avatar
piniongear
And I gotta apologize Doc.
I reread your post and what you said is correct.
I just misread it. Sorry.
pg
Old Aug 23, 2010 | 11:55 AM
gunnut1's Avatar
gunnut1
I have a 1970 that I bought new, that is not a 1970 front end either, 1970 still had the "boots" just like earlier sportsters. The seat is an after market one or a different year one. there were two seats available in 1970, neither one looked like that one. 1970 was the firs year that year that the XLCH and XLH used the same primary cover, the tin cover went away in 1969. 1970 had the ugliest chainguard that I have ever seen on a sportster (changed mine) that is not it. I think that you have a mixture of parts and someone used the 1970 frame to license it, that would have worked here in Virginia a few years ago. I will have to go look, but I think that my gas shut off is on the other side of the gas tank on a 1970. There was one for sale on CL here very much like yours, I sent the person an email telling them that it was not a 1970, only part of one.
Old Aug 23, 2010 | 11:58 AM
gunnut1's Avatar
gunnut1
Forgot one thing, an interesting thing, in 1970 an XLCH came with a 19 tooth countershaft sprocket and an XLH came with a 20 tooth.
Old Aug 23, 2010 | 12:04 PM
The Doctor71
again no prob PG. Apology not needed, but thank you for stating you just mis-read my post. We are on the same page.
Regards, Doc71
Old Aug 23, 2010 | 12:47 PM
josh221's Avatar
josh221
6th Gear
the last digit on the engine is a 0. So that confirms that the engine and frame are from 1970 and the rest of the parts mixed and matched from later years.
Old Aug 24, 2010 | 12:06 AM
sepixlh's Avatar
sepixlh
1970 was first year when VIN was stamped also to frame, same number should be in frame than in engine. Rest of the parts are not numbered.
ihb75
Ironhead
15
Aug 28, 2012 04:11 AM
laythss
Oct 12, 2010 02:51 PM
dyna_man05
Shovelhead
13
Apr 6, 2010 02:43 AM
mojocyclewerx
Ironhead
Jun 11, 2007 03:07 PM
togfish
Ironhead
Mar 23, 2007 09:34 PM
