Ironhead A place to talk about Ironheads.
Turn Signals
Old Feb 2, 2011 | 06:47 AM
grantb's Avatar
grantb
Default Turn Signals
Hello,
I am wanting to install front and rear turn signals on a 72 sportster that does not have any turn signals at all. Does anyone have any suggestions? Is there a kit that comes with everything needed(lights, harness, switch and etc.)? Thank you for any help!
Grant
Old Feb 2, 2011 | 06:57 AM
JayStronghawk's Avatar
JayStronghawk
Check this one out ....
http://www.jpcycles.com/product/3200526
Old Feb 2, 2011 | 07:02 AM
IronMick's Avatar
IronMick
Here's a wire diagram for turn signals. You can get the flasher at WalMart or any auto supply. Get the two-terminal one not a heavy duty one. It does not matter which terminal connects to 12 volts.
If you want to use LEDs i believe you will need an electronic flasher. You may need a load equalizer - i think not with the electronic flasher but i am unsure.
There should be a 15 amp circuit breaker between the battery +ve and the flasher.
The turn signal units are usually grounded to the frame or handlebar or whatever they are mounted, otherwise you would need to run a ground wire from each to frame.
Old Feb 2, 2011 | 12:21 PM
Neal Perez's Avatar
Neal Perez
i have seen a specific turn signal wiring kit on ebay, stil there and cheap too.
Old Feb 2, 2011 | 07:22 PM
Mr Bentwrench's Avatar
Mr Bentwrench
The lights, mounting & wiring don't hang me up but what do you use for a turn signal switch and where do you put it? The '72 bars are just soooo clean.
Old Feb 2, 2011 | 08:13 PM
IronMick's Avatar
IronMick
Has to be near one of your thumbs; has to be weatherproof. I suggest [partially?] under the handle bar so it does not show. Look thru J&P Cycles catalog for ideas. J&P 370-014 OEM 70058-50B would be a good choice as it was used on early Sportsters. Might be hard to find something you really like.
Tony Underhill
Electrical/Lighting/Alarm
Apr 20, 2017 07:07 AM
adotcorona
Aug 4, 2015 11:17 AM
A1exAri
Jul 5, 2013 06:15 PM
ws6lvr
Mar 22, 2013 03:04 PM
imboden
Apr 6, 2006 12:48 AM
