So I have new electronic ignition that came
With new suppression core wires. So once I strip
The insulation to get to the wire in the center do
Do I need to strip that wire or just fold it over and
Put the end on? What happens if I already stripped that
Wire will it still work ? Because that's what I did for some
Reason and could see that its just fibers not a metal in
Core. Guess I should have asked before I
Went to work with the strippers !
well if its not to short already just cut it clean and strip it back again but just fold it over this time and clamp on opposite side the folded wire is
