Ironhead A place to talk about Ironheads.
fuel problems
Old May 1, 2011 | 01:09 PM
IronMick's Avatar
IronMick
Originally Posted by IronMick
... What you can do is put a pop can shim between the pipe and the head [EDIT, i should have said between the pipe and the clamp]. ...
Just note this error correction.
Old May 2, 2011 | 08:34 PM
oil leak's Avatar
oil leak
Im not sure on what a pop can shim is anyway. I have some electrical rubber splicing tape I used to wrap the manifold. Fidgured it would hold out a little better than teflon tape or plain electrical tape.
Old May 2, 2011 | 09:15 PM
IronMick's Avatar
IronMick
Originally Posted by oil leak
Im not sure on what a pop can shim is anyway. ....
From a pop can cut a strip about 1/2" wide, long enough to wrap around the pipe; then install the clamp on the shim. This will make the clamp much more effective. Without the shim the clamp may completely close before it has fully tightened. With the shim the clamp will tighten fully without being completely closed.
enginesludge
Dec 21, 2014 09:16 PM
jfanton
Exhaust System Topics
Nov 25, 2014 07:30 PM
Bones665
Ironhead
Oct 18, 2011 07:27 PM
stevenlisa
Ironhead
May 23, 2011 06:02 PM
sellout
Ironhead
Nov 18, 2009 05:29 PM
