Starter issues escalating
It would catch for maybe 1/2 a revolution, the engine would put-put for a half second and then the starter would disengage from the engine, spinning free. After 5 minutes of stubbornly trying to make it catch (usually hitting the button twice in rapid succesion, holding on the second time would help) the button became completely un-responsive, not even a little click that it gives when the battery is too low.
It seems to be its an electrical issue, solenoid maybe? Electrically everything else on the bike is fine, Battery is charged to 12v on my multimeter.
With a fully charged battery, disconnect the small green wire from the solenoid. Now when you push the start button you should be able to hear and/or feel the start relay give a gentle click. If not then the button or the relay or the wire between them is faulty.
There is a procedure in the factory service manual 99484-** to test the solenoid. It is tested without being removed from the bike. That test would be the next step. ** is either 78 or 85 depending on the year of your bike.
It is possible that the problem is with the starter bendix, but that test waits until these are done; and i will not be able to help with it.
But it sounds to me like a low battery.
If you get no sound of clicking at all but the headlight is bright then most likely you have overloaded the starter by repeating the pressing start button over and over again without allowing it to cool off.
15 seconds of holding down the button will overheat things.
In this case look at the solenoid and the relay breaker for the starter.
It sounds like you have a low battery as long as you heard clicks.
No clicks...... suddenly........ makes me thing you overheated the system.
In any case charge the battery overnight and try again.
pg
I will get the battery inside and on the charger tonight. COuldn't afford an automatic one but I have a nice multimeter to let me know when to take it off. Its a little 1amp charger I got at autozone when I got the bike.
I went outside again to try it out, the lights all shine bright and horn works but the starter button is still unresponsive.
