Sporty died
So are you saying, after all the previous events, you then went for a 20 mile ride & your battery now reads 0v ? Or have I mis-understood you ?
Regardless, it sounds like you have something draining your battery.
Put your multimeter on it, set to 10 AMPs scale, (it does have a 10 AMPs scale doesn't it ?) & read the number of AMPs being pulled from the battery with the key off. It should read "0" zero..... but does it ?
Now turn the key on (no lights, run switch on, don't attempt to start it) it should read somewhere around 2-3 AMPs.... but does it ?
My multimeter has a non-contact ammeter and automatically switches so I will check that out next time I go outside. Would I put the ammeter around the ground wire or the positive?
I turned it off and tried again. Lights are on but bike wouldn't start. I jiggled the kill switch and midway between off and run, the bike started up. Took it for a 5 mile ride, battery still at 12v but still need to rock the kill switch when starting.
Would a sticky or bad kill switch completely drain the battery?
Looking at the wiring diagram, I don't see how a bad kill switch could drain the battery, but I'm no expert. All it appears to do is provide +12 volts to the coil when in the "run" position, and remove the +12 volts from the coil when in the "stop" position.
Your bike turns over when trying to start with the battery charged, right? And you have to jiggle the kill switch to actually get it to start?
I don't know why your battery drained to 0 volts on your 20 mile ride home from work. I think something else is going on to drain the battery that fast.
as far as your ammeter goes, either wire (+ or -) should work but I'm not there & can't see how your ammeter reacts.
My really old-school analog ammeter, which has to go in-line in the circuit, works on either + or -, the only caveat is you switch (reverse) the leads on mine when working the + side then going to the - side. I imagine your newer meter would switch automatically..... but I'm not there..... so try one side first (either + or -), then switch to the opposite side if your ammeter is not reacting the way you expect.
Personally, I usually start to troubleshoot electrical issues from the -ve side, but ONLY because the -ve battery post is easier to access.
If you're seeing a 0 (zero) AMP drain with the key off.... be sure to switch to a milli-amp scale (if your meter doesn't switch automatically) & re-take a reading. The whole idea, of this 1st step, is to confirm:
- the battery REALLY is being drained with the key off, and
- how large is that drain (aka is it draining at some small milli-amp rate or larger AMP rate)
The right handlebar switch housing is particularly tedious because of the brake light switch. I do not like to mess with it, and i do my best to ensure that it does not disconnect while i am working in there. Before i remove the bolts i wrap a length of stiff 14 gauge wire [stripped out of household electrical cable] around it and the h-bar so that it will not fall down when the last bolt comes out.
What is going on at the other location ?
It has been down all day Tuesday.
pg
ohhhh.
Is that how I was supposed to word it?
it makes for a long cold winter when there are online technical issues beyond our control.
I'll know for next time.
hahaha
Last edited by scottfisher; Feb 7, 2012 at 05:30 PM. Reason: spelling like a 2yr old
