Ironhead A place to talk about Ironheads.
need help
Old Jul 3, 2012 | 03:51 PM
EddieO''s Avatar
EddieO'
3rd Gear
Default pinion gear puller help
I checked the oil pump timming and its off.the hole in the breather sleeve gear doesn't line up with the breather bushing.its about 1/8 to 1/25 off to the right.I checked twice on my crank 40 deg advance mark..when I line the pump gears up the advance line is gone..could someone please tell me how to make a tool to get the pinion gear off.thanx
Old Jul 3, 2012 | 07:21 PM
IronMick's Avatar
IronMick
I have no experience with that pinion gear - the newer IronHeads p gear slips on and is held in place with a lock washer. However i believe that all you need to remove it is a simple puller from Princess Auto, Canadian Tire, Harbor Freight, etc.
There is a special tool for re-installing it. The main purpose of the tool is to set the precise spacing as given in the Factory Service Manual 99484-78. You may be able to re-install and get this spacing with ordinary tools.
Best to wait until someone with direct experience chimes in.
Old Jul 3, 2012 | 08:46 PM
EddieO''s Avatar
EddieO'
3rd Gear
Ok thanx man.yeah ill do that.
justgliding99
Oil Archive (no new posts)
Aug 15, 2018 07:24 PM
MrWhitaker
May 26, 2017 03:22 AM
Jbic68
Shovelhead
15
Apr 26, 2014 06:43 PM
dandanny81
Jul 29, 2012 12:18 PM
jokenroll
Exhaust System Topics
May 21, 2008 03:32 PM
