Ironhead A place to talk about Ironheads.
oil??
Old Mar 21, 2007 | 06:25 PM
paintballoma's Avatar
paintballoma
Default oil??
ok its the first time im getting the bike ready to ride since i got it. i wanted to know3 questions. i have a 1974 xlch 1000 sportster.first is i heard there are 2 diffrents oils in the bike one for motor and one for gear and the other is i heard that its all the same. the second question is do i have to buy harley oil or is there anything else i can use. also what about useing synthic oil or regulat oil.
Thanks
Waylon Renner
Old Mar 21, 2007 | 08:34 PM
nywarthog's Avatar
nywarthog
Default RE: oil??
Harley for years used the same oil in the gearbox as they used in the engine but that was with the dry clutch.After coming out with the wet clutch in the early 70's they used a "Sport Lube" in the tranny/front chain, I'm sure a 20x50 oil would work as well, there are a lot of aftermarket oils that will work as well as Harley oil. I personally wouldn't recommend a syntheticwith an Iron Head but I'm sure there will be peoplewho willdisagree with me.
Old Mar 21, 2007 | 09:05 PM
piniongear's Avatar
piniongear
Default RE: oil??
paintball...
There is a breather in your leftside crankcase that allows transfer of engine oil to primary/transmission case. Therefore, only use the same oil in the engine and primary/transmission.
The wet clutch first appeared in 1971. Before that the Sportster had a dry clutch. Same type of oil was used in both machines. Somewhere around 1977 this breather was removed and the trans got an addition of a vent hose, thus separating the engine from the trans.
But yours being a 1974, you need to keep the oil the same.
I recommend H-D Grade 75 oil in both places if you can find it at a dealer. This was a Harley marketed oil that was equivalent to a 60wt oil. Newer machines use lighter oil so it has disappeared in many places. I had a guy tell me he can get it up in Ohio. I cannot find it in Texas, so I run Castrol 70wt as a second choice.
If you live in a cold place you could run Castrol 50wt.
I would not run synthetic oil of any kind, and it cost far more than it's worth.
I would not run Pennsoil, Valvaline, Mobil etc, etc because of the additives.
You had another question regarding 'flashing the fields'.
This needs to be done when you have removed any wires from the generator, regulator or have removed the battery cables.
Here is what you have to do:
1) reconnect any and all wires you had disconnected.
2) Before starting the engine, momentarily touch a wire between the 'BAT' terminal and the 'GEN' terminal on the regulator. This surge of current will polarize the generator. Crank it up and have a good ride.......pg
p.s.......Failing to flash the fields can result in the polarity being reversed and this will cause the relay points to viabrate and bounce which burns up the points.
Old Mar 22, 2007 | 09:14 AM
sepixlh's Avatar
sepixlh
Default RE: oil??
ORIGINAL: piniongear
paintball...
Yep 1977 enginecases changed, left hand shifting (lever), new oilpump,no breathervalve...
Valvoline RACING 20W-50 can be used
Old Mar 23, 2007 | 12:03 PM
wizardry68's Avatar
wizardry68
Default RE: oil??
does this also go for the 72 ironhead?????
Old Mar 23, 2007 | 02:57 PM
piniongear's Avatar
piniongear
Default RE: oil??
If you are referring to what type of oil to use,....the answer is yes. The same applies to a 1972 ironhead......pg
statcar
Ironhead
Apr 14, 2025 05:46 AM
OddJack
Jul 29, 2014 11:17 PM
avn514
Oil Archive (no new posts)
Mar 14, 2011 08:24 PM
OneBlackFly
Jun 13, 2006 12:45 AM
HDF Tech
Aug 31, 2005 08:53 PM
