Knuckle Head A place to talk about Knuckle Head motors.
Charging System Issues
Old Sep 16, 2021 | 01:59 PM
lownslow's Avatar
lownslow
Default Charging System Issues
1941 FL, 6V system, all original. My riding trip to eastern oregon with other old bike dudes got cut short this week. My battery got cooked to death and I mean cooked!!! I had put in an AGM battery to get away from the original lead acid one. Got her back home and am going to drop the LA one back in and test the voltage from the regulator, which must be malfunctioning. Question, what's the best setup going forward. Have some gone to solid state look alike regulators? Cycle Electric setup? What battery are others running in that battery box? Suggestions welcomed.................
Old Sep 16, 2021 | 03:37 PM
johnjzjz's Avatar
johnjzjz
We convert to an electronic regulator with what ever fits your deal
the. Original stuck in yours in the on mode and did that
Old Sep 16, 2021 | 05:28 PM
lownslow's Avatar
lownslow
Thanks John, just fired it up with the LA battery fully charged and at a third throttle it climbed to 8.5 volts. yikes. Which electronic regulator do you like and does it hook up like the delco remy? Here's a pic of what I'm a runnin...
Old Sep 16, 2021 | 06:14 PM
johnjzjz's Avatar
johnjzjz
The electronic replacement is the exact same just up dated insides
Old Sep 16, 2021 | 08:07 PM
lownslow's Avatar
lownslow
Thanks John, I'll get one coming. Appreciate the time!
Old Sep 16, 2021 | 09:04 PM
lownslow's Avatar
lownslow
Where's your source, not finding good info online.....
Old Sep 17, 2021 | 06:17 AM
Architect's Avatar
Architect
Regulator will show up with metric screws. Re-tap one size up and the stock standard screws will fit. Five extra minutes for that extra detail.
Old Sep 17, 2021 | 08:07 AM
NiteOwl's Avatar
NiteOwl
V-tronic.com
I have his 6 volt regulator in all of my bikes. I have a knucklehead and still run the lead acid battery in there with the electronic regulator. An Indian has a gel cell one of those Shori natteries and it works just perfect with the regulator. I've got a panhead that is got a similar setup works just fine. All my generators have also been converted to to brush so I'm not having to adjust and that's it everything else is stock
Old Sep 17, 2021 | 11:16 AM
lownslow's Avatar
lownslow
Thanks NiteOwl, I got a little pissy with the LA battery as the vent hose came loose and it spewed onto my muff and frame a bit. Obviously now I know why, overcharging. Normal charge range it should just be venting not bubbling anything out the tube. It was fine for years until my regulator went wacko. I believe I'll be checking it periodically now, especially before heading out for long rides across the state.
Old Sep 17, 2021 | 12:54 PM
Architect's Avatar
Architect
On my Flathead, converted to 12V, I have the electronic regulator, older Cycle Electrics generator and a lithium ion battery. No hose, no acid, much cleaner setup. I have one of those fake battery boxes that looks just like an original 6V battery, Lithium sits inside with room for stuff. I have been setup like this for at least 3 years, no issues.
One warning, the electronic regulator is a bit sensitive, when working on electrics makes sure you disconnect the negative cable. Any short will go to the regulator first, and then you will be buying a new one. Good luck.
