Knuckle Head A place to talk about Knuckle Head motors.
oil tank question
Old Jun 27, 2008 | 06:40 AM
larry harding's Avatar
larry harding
Default oil tank question
i have a 42 knuck that is in a swing arm frame. i plan on putting it back in a riged frame this winter. catalogs (vtwin, jp) show a different oil tank from a riged to a swing arm frame but i can't tell what the phisical difference is. of course i don't want to purchase another tank if all i need to do is weld on a bracket or&nbsp\\;make some minor modification. i think it has something to do with battery hold downs, but i'm not exactly clear as to what. i can do some&nbsp\\; prety good fabricating if i know what is needed.
Old Jun 29, 2008 | 01:01 AM
FilthyLucre's Avatar
FilthyLucre
Default RE: oil tank question
You are correct the main difference is the battery hold down.&nbsp\\; On the 58 to 64 tank it has two tabs for the battery hold down rods to attach to.&nbsp\\; On the Rigid models they attached directly to the rear fender.&nbsp\\; They made&nbsp\\;4 or 5 variations of oil tank for the Knuckle head.&nbsp\\; The 40 to 57 type is similar to the 58 to 64 style with the exception of the hold down tabs.&nbsp\\;&nbsp\\; You will also need the rear mount that attaches to the fender in place of the one that attaches to the swingarm mount.&nbsp\\;
Brave dave
Sep 7, 2014 10:08 PM
venomous
Feb 25, 2009 06:20 AM
Billytoppless
Oct 7, 2008 10:22 PM
Toe Cutter
Ironhead
Nov 17, 2007 01:22 AM
79fatbob
Dec 28, 2005 06:46 AM
