Knuckle Head A place to talk about Knuckle Head motors.
jugs
Old Jul 21, 2009 | 03:47 PM
40 knucklehead's Avatar
40 knucklehead
Stage I
Default jugs
I have and 1940 knuckle with S&S 80 inch jugs on it only one hole on the head was pluged and redrilled. Does anyone know if pan or shovel jugs are a closer fit?
Old Jul 21, 2009 | 04:12 PM
FilthyLucre's Avatar
FilthyLucre
Knuckleheads have a different bolt pattern than pans and shovels. To use a pan barrel you will have to use a couple of stroker plates to make up the difference in height. The Easy Rider Tips and Tricks Vol 1 has an article on fitting a pan jug to a knuckle. If your heads are already plugged and drilled determine if the S&S barrel was a pan or Shovel. Use a head gasket to tell.
31choptop
Panhead
Nov 4, 2013 09:39 PM
Uncle Paul
Aug 19, 2013 02:26 PM
chopmafia777
Shovelhead
Jan 26, 2008 09:41 AM
Cynic
Shovelhead
Dec 15, 2007 05:29 AM
79worries
Ironhead
Sep 3, 2007 09:44 PM
