Knuckle Head A place to talk about Knuckle Head motors.
starter troubles
Old Aug 14, 2010 | 05:02 PM
lowtune's Avatar
lowtune
Stage II
Default starter troubles
Have a 75 1000 Sporty, the starter is almost a hit or miss when starting almost 50/50 chance wont turn over. could i have a starter going out or have other troubles.
Old Aug 14, 2010 | 05:06 PM
HOG_0308's Avatar
HOG_0308
It’s the starter. I had the same issues with mine on my 08 Ultra. There are several things which could be wrong, several tests which could be done to replace the part. I figured if one part is going out, how long before the rest would, so I replaced the entire starter. Took an hour of work, no big deal. Now I have done it, I could change the starter in maybe 30 mines.
Old Aug 21, 2010 | 12:28 PM
mayanruben's Avatar
mayanruben
Default Easy Fix maybe
Check your ground first, clean all the connections first. Then pull the stater, hook a battery up and give it a few shots.. If all that works out, buy a good stater, spend big one time..
watindes
EVO
Sep 29, 2013 10:48 AM
pd76
EVO
May 7, 2012 07:22 PM
boneyrooster
Jun 16, 2010 08:39 PM
c50plus
Dec 1, 2009 04:03 PM
lennox5024
May 23, 2006 02:21 PM
