Slip and assist question
Old Feb 27, 2017 | 06:55 PM
PirateRider's Avatar
PirateRider
Default Slip and assist question
M8 RGS, 3200 miles.
Hearing a "chirp" noise from left side derby cover area upon deceleration with clutch engaged. Does not sound violent or horrible. I had assumed it was the new (to me) clutch design. Does anyone else hear a chirp from this area upon decel? Anything I should worry about?
Old Feb 27, 2017 | 07:20 PM
ROCKOUT Rocker Products
Sponsor
Chirps are usually belt tension.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 27, 2017 | 07:43 PM
TwiZted Biker's Avatar
TwiZted Biker
Yeah I get the same thing on a 17 RK on the decel occasionally, believe I'm hearing the primary chain singing, damned auto adjuster sounds tight. Already checked the belt on mine.
Old Feb 27, 2017 | 08:10 PM
PirateRider
I will check belt tension again. Makes sense and the sound dos sound more rUbber than metal.
Old Feb 28, 2017 | 07:15 PM
PirateRider
Not the belt, listened again today, can the compensator make a noise on medium to hard throttle roll off ?
Old Feb 28, 2017 | 07:38 PM
TwiZted Biker
That or the chain chirping, I know the noise your talking about, not consistent just occasional and it bugs hell outa me. They will be into the primary when I take mine in for service, isn't right whatever it is.
Old Feb 28, 2017 | 07:41 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Check your transmission fluid level and your primary level. The clutch is design to slip some on a hard decel so pay attention to when it does it and let us know.
Old Feb 28, 2017 | 07:43 PM
lp's Avatar
lp
I mean just for the hell of it, spray some WD-40 on the front engine stabilizer Link.
Mine squeaked like hell when getting on or off of it (throttle).
Old Mar 1, 2017 | 08:56 PM
PirateRider
I will give this a shot, primary and tranny fluids are good. I really don't want the dealer cracking open the primary just to tell me it's the S&A clutch noise and is normal but I may take it in before summer long distance season hits. My concern is it's something that could cause a high speed rear tire lock up. I ride this scoot everyday to work at 70-80 on the hiway and a lockupmeven would be less than enjoyable😄
Old Mar 1, 2017 | 09:01 PM
TwiZted Biker
Not hearing that kinda noise so I'd venture your good to go there.
