Oil pressure gauge for M8
Old Aug 9, 2017 | 01:26 PM
Yardstick's Avatar
Yardstick
Default Oil pressure gauge for M8
Why can't you splice into oil feed line to the heads with a t fitting and then use a regular gauge? Hmm?
Old Aug 9, 2017 | 01:40 PM
DRBUICK's Avatar
DRBUICK
Originally Posted by yardstick
why can't you splice into oil feed line to the heads with a t fitting and then use a regular gauge? Hmm?
you can or at the oil sender in the block
Old Aug 9, 2017 | 01:42 PM
TomcatCV62's Avatar
TomcatCV62
as soon as you do it yardstick, post some pictures please.... thanks.
Old Aug 9, 2017 | 11:06 PM
ghostrunner's Avatar
ghostrunner
This has been talked about and came to dead end. Here is a link to what someone found out about the threads on the M8
Old Aug 9, 2017 | 11:50 PM
Max Headflow's Avatar
Max Headflow
Oil feed line pressure to the heads is not the same as pressure to the lifters / crank. You really need to know what the pressure is to the lifters and crank. Oil feed to the heads is for cooling only. No pressure needed, Only flow.
89FLHTC
EVO
53
Aug 14, 2019 11:57 AM
jd8181
Jan 15, 2013 08:24 PM
tazzzman
Oil Archive (no new posts)
Jun 5, 2012 05:45 PM
hddon69
Apr 29, 2012 08:34 PM
Booey424
Apr 17, 2008 09:37 PM
