M8 Clutch slips
Old Aug 10, 2017 | 12:05 PM
smokingjoe's Avatar
smokingjoe
Default M8 Clutch slips
I took the primary cover off and found some real fine substance looks like grit.
Clutch starting slipping this morning.
I stopped and got some syn3 and dumped the mobil 1 I am gonna fill it up with syn3 and ride, hope it stops slipping, but the fine grit looking substance bothers me ?
Anyone have any ideas/thoughts besides not using MOBIL 1 In the primary!!!!!!
joe
Old Aug 10, 2017 | 12:22 PM
BB59's Avatar
BB59
Make sure the clutch is adjusted properly both internally and at the clutch cable The Mobil 1 isn't be the issue although I would be running a primary fluid as opposed to motor oil in my Primary.
Old Aug 10, 2017 | 12:23 PM
smokingjoe's Avatar
smokingjoe
Well it never slipped until I put mobil 1 in it ? And it just a few minutes Im taking it out with syn3 in it.
Joe
Old Aug 10, 2017 | 12:32 PM
HDV-GLIDE's Avatar
HDV-GLIDE
I recommend the HD Formula + for the primary. NO MOTOR OIL.....
Old Aug 10, 2017 | 12:37 PM
BB59's Avatar
BB59
It only takes a few minutes to check the internal clutch adjustment. People have been running motor oil in their primaries for years with no issues. Not that I would but they have come that way for years.
Old Aug 10, 2017 | 12:38 PM
Northern Glide's Avatar
Northern Glide
Hyd clutch. Little or no adjustment.
Some grit is to be expected unless you have an overwhelming amount of grit in your primary.
Motor oil in the primary of certain type or specification could cause your clutch to slip.
Old Aug 10, 2017 | 12:40 PM
dyna rider's Avatar
dyna rider
Default M8
M8s don't have an adjustable clutch as it is hydraulic and there is no adjustment.
I personally wouldn't use motor oil in the primary at all. Either use formula plus or primary chain case oil. Ams oil makes it as well as Spectro.
Old Aug 10, 2017 | 12:45 PM
RandyL's Avatar
RandyL
I also recommend the formula+
Old Aug 10, 2017 | 12:56 PM
Brewmany's Avatar
Brewmany
Didn't HD back off a couple years ago now, on it's recommendation to use Syn3 in the primary? Or did they revert back?
Old Aug 10, 2017 | 01:00 PM
ORradtech's Avatar
ORradtech
M8 clutch slip = warranty trip to dealer.
By dumping the grit you may have lost a valuable tool in troubleshooting the problem...
