New Screaming Eagle Pro Street Tuner software
I have a 19' m8 114 with a stage 2 kit and a SE tuner. The dealer installed the stage 2 kit and tuned the bike and it ran great for about 500 miles then started to run poorly, loss of power, vibration, sounds muffeled, etc. My question is this, is it possible the bike lost the tune? Should I try to flash the bike? Would that likely help? My dealer is 3 hrs away so looking to fix it meself. TIA
eanspratt (07-28-2021)
I don’t think you have anything to lose by reflashing, as long as you have the Stage 2 map in your tuner. The ECM is a solid state device, and shouldn’t just “lose the tune”. There is most likely an underlying issue that might throw a code that you’ll be able to see with the tuner hooked up. A little investigating and patience goes a long way, before you have to take a three hour ride to have the dealer shrug his shoulders and go, “maybe it was bad gas, but it looks good now”. FWIW.
yzernie
The Dyno Room
10-06-2016 06:17 PM
