yeah, following the manufacture's break in procedure is harmful to your engine and it will become a turd..okee dokee then...if you say so
You don't believe everything the Moco says do you? They are trying to cover their own butt. Nothing more. Motors in general like to be loaded and run in hard to build up enough heat and help seat in the rings. You only have one shot at getting a good ring seat. Ever wonder why some motors seem to run better than others. Many times it is because of break-in procedure.
yeah, broken in over 30 new bikes from 2 stroke mx to many Harley's in the last 40 years..never had any sort of issues related to the way I perform them..I'll just keep doing what's worked well..Oh Wait, this was the last bike I'm ever buying, forgot about that!!!
Think I caused any harm with the handful of times I tapped 4k before shifting up to this point?
IMO, no.. Lugging them is what hurts em. If your bouncing the thing off the rev limiter, yeah, that's no good. But that's at 5 grand on a stock bike. Your fine.
Seat the rings after letting it warm up by accelerating/decelerating between 30-45-30. Half throttle in second or third (can't remember). Do that 8 times and you are good to go. I've done it on my TC 107 right after I built it and never burned a drop of oil.
This. You want to build vacuum as that is what seats the rings. Find a long stretch of downhill road and coast down, in the next lower gear that you would normally do for the speed your going, with the throttle closed.
Don't lug it (shouldn't do that anyway) and don't redline it... then change the oil at 500 miles and let 'er rip.
I don't believe in the babying version either. When I leave the dealer, which happens to be on a service road right before a hwy on ramp I hammer it out of there and run it up through the rpms in every gear. Do some good engine breaking and some wot runs and by the time I get home I'm comfortable its been broken in just fine.
The engine is ran at the manufacturer before it even leaves for the dealer so technically its already broken in. one or two heat cycles is all that's needed. Not much else is going to change in the next 500-1000 miles. I am big on initially changing the oil out after a 100 or so miles because there will be material in there that needs to be drained out.
IMO- In reality by the time we get the bikes the engine has seen many revolutions. At the factory I would imagine they at least spin test them. And I don't doubt the engines run at least enough to get up to temp. Either as a check or to move them around prior to shipping.My bike had 11 miles on it when I got it. In all the hundreds of engines I built, break in consisted of starting it, the usual leak check, make sure the vitals are good and drive it. They don't break in car engines at the factory and they get driven all over pre and post shipping, with no concern over break in. The trans I can see as having a need to let the parts "marry"to each other to operate smoothly. Engine , not so much.
Glad I'm getting some back up on this. These motors don't need to be babied. Now you don't want to be bouncing off the rev limiter all the time but run them like you will run them. Let er rip.
Hmmm. Broke in several bikes and my method would be to take it take it easy first 50 miles. After that pretty much ride it like you would normally with trips thru the rev range (usually freeway on ramps.) SHORT rips shouldn't hurt a thing and maybe be beneficial in everything seating properly
