Hope I didn't make a mistake - Amp install
Old 04-27-2018, 05:22 AM
nobodyknowsme's Avatar
nobodyknowsme
nobodyknowsme is offline
Received 14,658 Likes on 6,424 Posts
Question Hope I didn't make a mistake - Amp install
Bike has been in the shop for a while having a bunch of things added. One is a Hogtunes amp and speakers. Had a call from my Indy yesterday that the kit did not come with a connector plug, can't remember which one. Been without the bike for too long so I told him to just hardwire it into the system. Then talking to a friend last night he mentioned the CANBUS.
So my concern is might I expect issues going forward? The Indy is very trusted and only works on Harley but don't guess he has worked on too many M8's as far as this particular install. Just hoping this is not going to be a problem and if so can it be reversed?
Old 04-27-2018, 06:30 AM
marshallb's Avatar
marshallb
marshallb is offline
Since this is the M8 forum I'm going to assume it's '17 or newer in which case I am willing to bet the indy plans to run speaker level input to the input of the amp which is no bueno. If however there is a BT line leveler involved it will be good. I am not aware of a true plug and play system for Rushmore bikes but it's as easy of an install as it gets. Find out if you received a biketronics line leveler and go from there.
Old 04-27-2018, 06:39 AM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,376 Likes on 2,625 Posts
Line leveler would work, but not ideal. J&M, Soundz and other trusted experts recommend flashing vs line levelers, I would contact them for details.
Old 04-27-2018, 06:45 AM
marshallb's Avatar
marshallb
I think if you head over to the Audio forum you'll find several threads that discourage flashing in most cases. Everything I posted in this thread is verbatim what I read there from respected members.
Old 04-27-2018, 07:15 AM
Keithhu's Avatar
Keithhu
This is what the guy from Soundz says:
Me: Flashing vs line leveler - pros? cons?
Flat eq vs a horrible signal quality with lots of distortion in the signal.
The “line levelers” are a terrible gimmick that is truly just a line out converter with two more gain pots added in an attempt to “sell” the public on the idea that it is to adjust bass as though it’s an in line -6db input crossover which is just not truly possible in this scenario.
You encounter two internal signals engine off vs engine on, a variable bass algorithm, and an output IC chip change at half volume with a drastic increase in distortion when left with a stock flash.
When flashed per our setting, we have one EQ curve on the radio, the voltage is reduced to the point that the distortion is almost eliminated, and the bass algorithm is also eliminated.
Anything ever sold as a magic box or line leveling device is simply a company after a fast dollar that cannot innovate and provide the solution or one that does not have the ability to tell their customers the truth while selling a low end product.
Only con to our flash is loss of fade. All [subsequent Harley] updates work fine. Nothing tricky about it, just don’t believe everything written online in forums!
We now have a DSP with canbus control that retains fade and provides a superior sound quality signal in conjunction with the flash.
Old 04-27-2018, 08:25 AM
marshallb's Avatar
marshallb
Again if you go to the audio forums right here on this forum one of the most respected places to get information from people who aren't paid to sell you something you will read that the Biketronics line leveler is the way to go. But hey if the salesman say it so mote it be.
Old 04-27-2018, 09:15 AM
Keithhu's Avatar
Keithhu
Biketronics is trying to sell something too no? Peter has an excellent reputation, with tons of thrilled customers, thats what I'm basing my opinions on.
Old 04-27-2018, 12:21 PM
marshallb's Avatar
marshallb
You win dude. Good luck OP!
Geary Thomas
03-01-2018 12:10 PM
black01
Audio Systems
10-11-2016 07:20 AM
Liquidoxygen
Audio Systems
03-28-2015 03:27 PM
dirtracin23
Audio Systems
28
12-06-2014 05:31 PM
T K Glider
03-27-2012 07:00 PM
Quick Reply: Hope I didn't make a mistake - Amp install
