Vibration ??
Old Jun 10, 2018 | 07:55 AM
JHC210's Avatar
JHC210
Default Vibration ??
I took the tour pak off and now while riding, I feel a vibration. I can't tell where it is coming from. Just feels like a rough road. I do have new Ohlins on so I am wondering since I pulled the tour pak off, maybe that could be the cause.
Old Jun 10, 2018 | 08:13 AM
mjwebb's Avatar
mjwebb
interesting..so immediately after removing the tour pack you noticed this that wasn't there prior? you could put it back on and see if it immediately goes away I suppose..or maybe have someone help you set the preload/sag correctly if it isn't already..can't imagine the weight of the tour pack would make a big difference but maybe the new Ohlins are more sensitive to adjustments..think I would do both those things one at a time to try and isolate and identify the cause..could be something coincidental too like a wheel weight fell off or tire pressure changed..dunno' but good luck
Old Jun 10, 2018 | 08:45 AM
$tonecold's Avatar
$tonecold
I would check the mounts for the tour pak if it started immediately after you removed the pak. Possible that one or both are a little loose and vibrating. Other than that I don’t know what to tell you.
hammer136
May 5, 2019 10:14 AM
wheely
May 22, 2014 08:46 AM
Dew Me
Jun 13, 2012 07:28 PM
remike
Aug 20, 2011 11:29 PM
08HD
May 18, 2008 05:20 PM
