rough idle on m8
Old Jun 21, 2018 | 11:37 PM
TwiZted Biker's Avatar
TwiZted Biker
Idle getting erratic is how I know my clutch safety switch is flaking out again, so far a drop of lube on the plunger has cleared the issue up for several months before needing it again. Try starting the bike in gear, it won't the switch is funky.
Old Jun 22, 2018 | 05:17 AM
billbrummett's Avatar
billbrummett
been there, done that! it's the clutch safety switch. I had 3 replaced before they got one to work. Harley redesigned it and there's a service bulletin on it. fanning clutch in traffic at bike week almost got me killed, the thing was reaching and loping. it may or may not start in gear, or be intermitttent. tell dealer it is a safety issue, it will wake him up and he will replace the switch.
Old Jun 22, 2018 | 09:08 AM
dslade's Avatar
dslade
Stage II
Originally Posted by cmashark
EITMS turned on?
the eitms is off
Old Jun 22, 2018 | 09:36 AM
VDeuce's Avatar
VDeuce
Originally Posted by dslade
the eitms is off
Does it start in gear with clutch pulled in? If not, clutch switch is bad as mentioned above.
Old Jun 22, 2018 | 09:58 AM
Drezultra107's Avatar
Drezultra107
I will try and see if it starts with the clutch pulled in and in gear but last time it stalled I tryed to restart while rolling in gear would not restart until I stop in put bike in neutral
Old Jun 22, 2018 | 11:09 AM
KrustyKush's Avatar
KrustyKush
I struggled with erratic idle for the first 3k miles on my new 2018 RGU. It never actually died on me, but it came real close, and at times was a serious distraction when taxiing a parking lot, especially with my pax on-board.
Once I learnt it was being caused by the clutch switch, I took bike to dealer shop, found out HD has a new re-designed switchback and lever assys, got them replaced, and it has been perfect ever since.
Erratic idle is apparently first signal of clutch switch problems. Also, inability to start the motor in-gear with clutch lever pulled. It will probably be intermittent. It will come and go. Sometimes it will start in-gear, other times not.
The service writer didn't even look at the bike. I described the issue symptoms, and he replaced the clutch switchback and lever.
Old Jun 22, 2018 | 11:36 AM
mjwebb's Avatar
mjwebb
I pick mine up today with the supposedly new part # so hoping this will put an end to these particular woes anyway
Old Jun 22, 2018 | 01:26 PM
TwiZted Biker
Clutch switch is funky and that's your idle problem. Have no clue how or why they are related but it is.
Old Jun 22, 2018 | 01:47 PM
VDeuce's Avatar
VDeuce
That switch is connected to the ECM via canbus, so who knows what the ECM does with it.
Old Jun 22, 2018 | 06:58 PM
Teufelhunden's Avatar
Teufelhunden
Maybe if the ECM does not know that the clutch lever is against the bar, it thinks the bike may still be moving (even thought the speed sensor tells it differently) and tries to feed a little extra fuel to keep it from dying while moving so slowly that it won't register on the speedo???????
Lon
